RV.Net Open Roads Forum: Class A Motorhomes: Electric step not working
 > Electric step not working
ShutterStuff
Port Angeles, WA USA
Posted: 06/28/08 12:14am Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone. I will give these a try in the morning.
Sheldon
Qapla´ from the house of K'ler
1988 31' National Dolphin 3140
Amateur radio IS a contact sport!
N7XEI
Boblou
Posted: 06/28/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2002 Damon Intruder and shortly after bringing home the steps quit working. I scooted under the MH and saw where the steps were grounded to the frame. I unloosened the bolt, cleaned the fram where it was connected, cleaned the wire end and put a new bolt back in and it worked wonderful. I has been 2 years since. This may not resolve your problem but it might and it certainly is the cheapest thing to check before more costly step replacement
mhconversion
canada
Posted: 06/28/08 07:47pm Link  |  Quote  |  Print  |  Notify Moderator
funny thing happened to me last weekend my step would not go in after being out for three days. but at the same time my leveling leg on the the front would not go up. but after I got the leg/jack up the step worked.
peaches&cream
Northwest Georgia
Posted: 06/28/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
I just got mine to working 2 day's ago. It is a Holiday Rambler so I do not know if things are located in the same place, but I bet they work the same. Look under the MH, above the step on the frame and the 4 wire connector should be there. I unplugged the connector, took a test light and found no current on the red wire. The red wire should have current at all times. I found a breaker under the front hood, over the radiator (gas MH). The breaker was corroded where it mounted on the buss bar. Disconnected the chassis battery, removed the breaker, cleaned the buss bar with scotchbrite, reinstalled and it works great. Be sure the on/off switch in the MH is in the off position while working on the steps.
Hope this helps,
Larry
1995 Holiday Rambler , F53, 460, Banks Exhaust & Trans Command
Toad 1995 Miata
ShutterStuff
Posted: 07/16/08 12:26pm Link  |  Quote  |  Print  |  Notify Moderator
I forgot to follow up on this. It was both a dirty connection and needed some lubricant. It works fine now.
steelpony5555
Copperas Cove Texas
Posted: 07/16/08 12:44pm Link  |  Quote  |  Print  |  Notify Moderator
Check the lights by the switches--if they are dimmly lit then it is a good chance you have a bad ground---Dave
05 Trail Bay 27DS
07 Tundra SR5 4.7
00 Harley Electra Glide (My Baby)
07 Civic for cheap gas
Margarita machine---nothing better then sittin in the shade on a hot day sippin a Margie!
daverich
Northwest Missouri
Posted: 07/16/08 12:46pm Link  |  Quote  |  Print  |  Notify Moderator
garry1p wrote:
Before changing any parts.
Common problem;
The 4 wire connector to the steps gets corroded and won't pass 12VDC or acts as a resistor and won't pass enough current to run the motor.
That was my problem. Cleaned it up and plugged it back in and all is well.
Wherever I happen to park
Posted: 07/16/08 02:08pm Link  |  Quote  |  Print  |  Notify Moderator
If it's a kwikee step and it is extended you may be able to pull the pin and retract it by hand, use a bungy cord to secure it for travel
If it retracted.. You have a problem
To do this you will need.. One pair eyes, one small (10-12 oz will do) hammer and one partner
With the override switch off or the power switch on (Depending on the age of the steps) get under the rig where you can see what's up there but AND THIS IS IMPORTANT.. you won't get hit by the steps.. Take hammer
Observe the light.. Is it on? NO: Have partner open door, Yes: Have partner close door
Did the light change status: IF yes, then good. Skip to "OTHERWISE"
If no, then if the light went from OFF to OFF.. Test and replace lamp if needed
If the light went from on to on, Door switch is defective/not working or the magnet has moved and is not activating the switch.
OTHERWISE: motor may be frozen or have a dead spot
Tape gently with hammer a few times (YOU DO NOT WISH TO SMASH IT... YET) and have partner try again... Repeat a few times (CAREFUL)
If it works.. Read the threads about the Ford or Lincoln replacement motors for Kwikee steps
Cousin_Eddy
Peoria, AZ
Posted: 07/16/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have a used control board and motor for a 1995 Kwikee step if needed. PM me.
1995 33' Southwind Fleetwood Model LW
garym114
Posted: 07/16/08 06:29pm Link  |  Quote  |  Print  |  Notify Moderator
When I got mine out of storage this spring in Anchorage my steps would work only when they wanted to. Traced it down to the motor, no motors available in Anchorage, so I pulled the motor. When I took the motor apart about two tablespoons of water came out. I dried it out, greased it a little and cleaned the brushes and commutator, put it back together, lubricated the steps and it has worked ever since.
2000 Sea Breeze with 1998 CRV Toad in Dawson Creek - Start of Alaska Highway
Don't Forget - USS Liberty, June 08, 1967
