RV.Net Open Roads Forum: Fifth-Wheels: greasing 5th wheel pin or locking jaws?
 > greasing 5th wheel pin or locking jaws?
rmontez
Wisconsin
Posted: 06/27/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
Do any of you grease the pin on your 5th wheel or any part of the hitch? I use a lube plate but when I turn or when backing into a camping spot there seems to be allot of squeeking and what sounds like hard turning pressure caused by metal on metal. I hope that makes sense!
sdfleetwing
SD
Posted: 06/27/08 09:27pm Link  |  Quote  |  Print  |  Notify Moderator
I use a spray can of silicone, works for me.
C Schomer
Buckeye, Az.
Posted: 06/27/08 09:59pm Link  |  Quote  |  Print  |  Notify Moderator
I grease the small part of the pin and spray all the pivot points on my hitch with chainlube. Craig
2003 Dodge HO CTD, NV5600, 4.10. Real 1Ton - pregnant with twin spare tires, 4WD - all on the rear. Aurora 2000 turbo, Diablo Predator, 4" muffler. 98 Sunnybrook 30RLFS 5th wh. WHOEVER INVENTED WORK DIDN'T HAVE AN RV!
dbbls
Missouri
Posted: 06/28/08 04:41am Link  |  Quote  |  Print  |  Notify Moderator
I put grease on the pin.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
fpresto
Maryland
Posted: 06/28/08 04:55am Link  |  Quote  |  Print  |  Notify Moderator
Anyplace that metal rubs on metal should be lubed.
USN Retired
2007 Cedar Creek 30 RLSTS
2008 F350, DRW, V-10, B&W hitch,
Pressure Pro, JT Strongarms
SweetLou
La Quinta, CA USA
Posted: 06/28/08 05:01am Link  |  Quote  |  Print  |  Notify Moderator
I use grease on the pin and clean the jaws and put white lithium on all working parts on the hitch. I also put white paint on the Jaws so I can see better if they are closed.
2005 3500 Cummins HO Quadcab 4x2 3.73 6 spd man, 2007 HitchHiker Discover America 329 RSB
Hamops
Oshawa, ON, CA
Posted: 06/28/08 05:34am Link  |  Quote  |  Print  |  Notify Moderator
Now that's an idea that I'm going to use.
Helen & George VE3INB and Max (Bichon Frise)
06 Silverado LT 2500HD D/A
2006 Crossroads Cruiser CF30SK
Prodigy Brake Controller
16K Reese Slider with
a Bedsaver
Cox89XJ
Tennessee
Posted: 06/28/08 06:13am Link  |  Quote  |  Print  |  Notify Moderator
I painted my jaws also. Helps about seeing the jaws are shut. I use a spray grease on the moving parts of the hitch. I use the lube plate. I don't see any use of greasing the pin. I think not lubing the pin is not going to wear any thing out. Just create a mess.
Ray,IN
IN, USA
Posted: 06/28/08 06:37am Link  |  Quote  |  Print  |  Notify Moderator
A lube plate only affects downward force on those surfaces, it does not lubricate the 5th wheel pin. The pin must be lubricated just the same as any moving parts. The steering parts of your tow vehicle move and you lubricate them don't you? Same type action and forces are imposed on the ball joints and tie-rod ends.
For those that do not lubricate the pin, reconcile those facts please.
ryoung
Indiana
Posted: 06/28/08 06:38am Link  |  Quote  |  Print  |  Notify Moderator
Anytime you have moving metal to metal contact you are going to have wear. Lubrication will reduce the wear.
I use a lube plate, chassis grease around the king pin, grease on the side to side swivel pin, and once a year pull the hitch head, turn it upside down and squirt all internal parts with 20 wt motor oil. After five years the hitch looks and works like a new one.
ryoung
2004 Dodge 3500 Dually HO 6 sp 4.10, Jordan Controller
2005 SunnyBrook 31BWKS
2004 Lance Lite 915
