RV.Net Open Roads Forum: running a/c in warm humid weather question
 > running a/c in warm humid weather question
firedude
On the road
Posted: 06/27/08 10:17pm Link  |  Quote  |  Print  |  Notify Moderator
The 'ol firedude is used to being on the coast and places cool. Right now helping my dad following my moms passing a couple months back. it's pretty hot here in the summer. Usually in the 100's and humidity around the high teens to low 20's. Lately the past few days the humidity has been around 45+%. A/c didn't seem to be as affective. Someone suggested cracking a vent just a wee bit. I did and the temps seemed to drop about 7 degrees inside so far.
Do you who live/camp in the high humidity leave a vent or window cracked for air movement/circulation? seems reasonable as to allow any warm air to be pushed out as long as it's a very small opening so as not to let out all the cool air lol! Seems if I keep it somewhat air tight it gets stuffy and doesn't cool as well in the high humidities. With the norm in the upper teens to ow 20's it doesn't seem to be a problem. Man I've been spoiled by the coast and pacific northwest!
Tony
Kajtek1
CA
Posted: 06/27/08 10:21pm Link  |  Quote  |  Print  |  Notify Moderator
When you take a steamy shower and let the air circulate inside the house, usually the smoke detector will go off. You should know that already?
AC dries the air. You don't want the moisture to enter you rig voluntary? Our rigs are not that well sealed, so don't worry about breathing air. Let the moisture stay outside.
One of the problem you might experience is that AC compressor working at 100% duty might over-freeze the coils. Don't know if RV AC has defrosting mode, so good idea would be turn it off every couple of houris for about 15 minutes.
Pessimist sees dark tunnel, optimist sees a light at the end, realist sees lights of coming train.Engineer sees 3 idiots on the tracks.
trnfla
Tampa
Posted: 06/28/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
we keep all the vents and windows closed here in steamy FL. The a/c takes time to remove the moisture from the air.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
CSpenceFLY
Macon,Ga
Posted: 06/28/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
I leave the bathroom vent cracked. I figure heat rises so why not give it a place to go.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
Oakman
MO
Posted: 06/28/08 07:00am Link  |  Quote  |  Print  |  Notify Moderator
We open the vent in the highest part of the trailer (bedroom) about an inch and yes, it helps considerably in places with high humidity.
2002 Dodge 2500 V10
2008 Wildcat 28RKBS
Honda 2000 gen
TomTom One 3rd edition GPS
Ray,IN
IN, USA
Posted: 06/28/08 07:25am Link  |  Quote  |  Print  |  Notify Moderator
The single best thing you can do to keep your RV cool in high temperatures is to run your A/C constantly, set at the desired temperature. This allows it to maintain temperature/humidity rather than playing catch-up all day.
Opening windows at night just allows high humidity to invade your RV, where furniture, bedding, etc; soak it up. Now your A/C must work doubly hard to obtain the desired results, remove it again.
Keep in mind an air conditioner is actually a large de-humidifier. Cold air is a byproduct of what the inventor of a de-humidifier was attempting to perform.
That said, this is why "swamp coolers"(add moisture) work well in low humidity(deserts) but not in the Midwest, where the humidity averages near 70% in summer. Air conditioners (remove moisture), therefore do not perform well in desert climates, but work very well in high humidity climates.
Opening your RV to outside air only increases the workload on your air conditioner. RV air conditioners re-circulate interior air. They are designed to operate with a temperature differential of 20* between intake and discharge air. This means as your interior temperature drops, so does the discharge air temperature from the A/C unit. Of course there are limits.
BTW, right now Indianapolis says the temperature is 71*F, humidity 91%.
* This post was last edited 06/28/08 09:28am by Ray,IN *   View edit history
MotherOwl
Northwest Louisiana (ArkLaTex)
Posted: 06/28/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
I live in Louisiana where it is very hot and VERY humid during the summer. I don't open a vent nor have I ever heard of doing so. In fact, I always put those foam pillows into my vent openings. If you have no shade, it will also help to put those reflective covers over your skylights and windows facing the sun.
Stay cool, firedude. I'm not a fulltimer, but I always enjoy your posts.
Mother Owl
K-Z Frontier 2405
butkus21
On Galveston Bay
Posted: 06/28/08 07:41am Link  |  Quote  |  Print  |  Notify Moderator
I tried opening one of the vent's and it felt like the humidity increased inside the trailer. I run both a/c's round the clock, leave the shades (blinds) closed during the hottest part of the day and never run the ceiling fan since it seems to draw the heat down. I do have thermal pane windows and more insulation in this trailer, but its still a battle. I'm not looking forward to my next light bill, lol. If you have some shade to park under that will also help. Good luck!
Terri
Mobile Suite 36 RS3
05 F350 FX4 Lariat PSD CC DRW
05 GMC C4500
Click for pics
hitchup
Fulltiming in Madison, VA
Posted: 06/28/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
We also always keep our vents shut and skylights covered so the 2 AC's can do their job. But I've started running a table fan to keep air circulating in any room we're occupying, so I can set the AC temps a little higher as the heat outside increases and keeps AC's running more frequently.
When we had our Open Road, the one 15k AC would freeze up. Suggestion from dealer was to run the Fan on HI rather than AUTO. That meant the fan was on all the time, not just when AC kicked on. It wouldn't keep us much cooler, but did prevent freezeups. We haven't experienced that problem with our Suite.
2009 DRV Mobile Suite 38TKSB3....our custom home
2008 Ford F450 Lariat CC 4x4......his office
Working Fulltimers since 3/2005
"Shoot for the Moon! Even if you miss it, you will land among the Stars."
firedude
On the road
Posted: 06/28/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
OK, first of all sylight ect were already covered, reflectix in the windows on the sun side and all the other tricks. it's pretty hot where I am (not by choice lol).
Now, I tried something here and was actually amazed. I cracked one window ever so slightly, maybe 1/8th of an inch or so. It made a huge difference. Temps are now staying at or near where I have the thermostat set at what a big difference it made! A big gap between inside and out unlike yesterday evening. I figure as the inside tries to heat up the warmer air has to escape a little in an exchange manner if you would. Either way cracking that one vent made all the difference in the world AND I'm only using my portable a/c too! Go figure. Incidentally my inside humidity always runs pretty consistent and always much lower than outside in high humidity areas. Thanks for all the input gang!
RV.net Blogs, a world of info!
My RV.net Blogs
My RV Blog
Retired Fire Captain Full-timer Rv'er
RV.net Moderator
