argent1957
South Carolina
two carrier 13,500 units...rv is new as of April 2008...
New RV'er
Damon Astoria 3776 (Bunk Beds)
Diesel Pusher 38' Freightliner
urmine351
fort smith, arkansas
Looks like a warrenty item to me then, I would be getting ahold of them.
1996 Safari Serengity, 3126 Cat,Allison 6 speed, 38' DPNS, 2005 Honda Element,vip tow brake. doran tire sensors, Magellan750Nav,
and 1 good looking wife, and missy and Alex(died 11-03-06) and AJ, born 09-06-06 my carins.
FMCA # F374886
argent1957
South Carolina
I am on the road and can't check the voltage on the genset right now..thanks
FrankReno
Reno, NV
When I have a tripped breaker the easiest first fix is to replace the breakers. Simple not expensive.
Frank & Marion
2004 Southwind 36B
Workhorse W22
Little Green Jeep Toad
Driver Jake The Wonder Dog
Copilot Chip the Pup
RLS7201
Gladstone, MO
Another possibility is a loose connection at the breaker. Feel the breaker, the next time it trips, and see if it's warmer that the other AC breaker.
Richard & MichĂȘle Shields
Northland Good Sams
1995 Bounder
32H F53
Banks, TruTrac, Vena
2003 PT Cruiser Pusher
FMCA 395470
Web Page
Retired and traveling on your hard earned SS $$. Thanks for your support.
Locomotiveman
Willmar, MN
Argent 1957: Buy a cheap Voltage meter.($6 or 7 bucks) and plug it into any outlet where you can always look at it. Mine is next to the front seat. You will like knowing your voltage. Leave it plugged in forever. TOM
Locomotiveman..Yes I am a career cross-country Locomotive Engineer. Wife is an RN. We are CLOSE to retiring and 'downsized' to a Monaco Executive w/450hp Cummins and nice drapes. Locomotiveman
cvrvr
La Crescenta, CA
I have two 13.5k BTU a/c's that run all day long on a 5.5 Kw Onan with no problems. Sounds like you have a problem with your front A/C.
George
George & Karen W
2004 Allegro 30DA
2000 Jimmy toad
FMCA F334632
WGLASSJR
NORTH CAROLINA
I have two 13500 btu air units on mine with a 5500 onan marquis gold gen.I cannot use both my units while driving it kicks the breakers on the generator.So i only use one and it does get hot in the coach.Went to yellowstone last august out rt-90 it was 109 degrees im told you cant run both units at the same time with a 5500 gen when traveling.Maybe there is something wrong with mine
Ryles
Woodstock, GA
We have a 5500 and can run both airs all day long. No reason you shouldn't be able to run 2 airs on a 5500 watt generator. 5500 watts is somewhere around 45 amps. 2 airs both running/starting up at the same time will draw less than that. I think they draw 18-20 starting up and 15 or so running.
garry1p
Broken Arrow, OK, USA
Since the rear works OK I suspect a loose connection my best guess would be at the transfer switch since you run fine on shore power.
If you know enough about your coach to find the transfer switch with the generator off & NOT plugged into shore power check for loose connections starting at the transfer switch.
Garry1p
1990 Holiday Rambler Aluma Lite XL
454 on P-30 Chassis
1999 Jeep Cherokee sport
