RV.Net Open Roads Forum: Travel Trailers: Power Awning Pictures
 > Power Awning Pictures
Mikesr
Lebanon Pa
Posted: 06/28/08 12:20pm Link  |  Quote  |  Print  |  Notify Moderator
Seems like many are having problems with the new power awning being uses by A & E on the new TT's. We do not like ours either because the rain water does not drain off. Here are some pictures that might show why.
As you can see the roller is about 2 inches higher then the edge of the awning material. This seems to be causing a damming effect for the rain water. Ours has already started to stretch as you can see.
Something needs to be changed in the design of this awning. It needs to be able to be adjusted so that rain water can drain before someone gets hurt from a collapse.
Mike and Donna
2005 Chevy 2500HD
2009 Flagstaff 831FKBSS
trnfla
Tampa
Posted: 06/28/08 12:37pm Link  |  Quote  |  Print  |  Notify Moderator
Sometimes the old way is the better way.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
JJBIRISH
Butler, PA, USA
Posted: 06/28/08 01:59pm Link  |  Quote  |  Print  |  Notify Moderator
I know nothing about the power awnings, as I have never looked at them...
my awning when open looks much the same as yours, when unrolled the seam is not at the top of the tube, and even less so if I put the legs down in the carport set-up... this has never caused a problem, but I always have enough of a angle to prevent pooling...
the sagging in the middle I think is pretty normal and is what makes angling the tube a must... otherwise the slope is all that would be needed...
I always thought the power awnings were designed to dump water if it started pooling...
is this a wrong assumption about them???
I sure don't like the new awning material they are using with their sunchaser model... it is laminated layers instead of the original type, (molded layers color clear through... they should be ashamed of the poor quality of their lamination process...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
firemedic16
Between Boston and Providence
Posted: 06/28/08 02:29pm Link  |  Quote  |  Print  |  Notify Moderator
I have the same problem on my 2008 keystone sprinter. The water pools so much that the awning will not retract. I have to climb onto the picnic table and push the pool off. Also, I think this has caused the supports to warp and not retract all the way to the side of the trailer.
subourbon
Huntsville, AL
Posted: 06/28/08 03:59pm Link  |  Quote  |  Print  |  Notify Moderator
The awning on my Jayco 31E is a CareFree and automatically dips to drain water, then straightens back out.
Happy Camping
2007 Chev. Silverado CrewCab 4x4
6.0L Vortex Max
3.73 Rear Axle Ratio
Prodigy Brake Control
Equalizer Hitch
Champion 4000/3500 30A RV Gen.
Garmin 7200 GPS
2008 31E Jayco Feather LGT
UVW6225 GVW7850
ROBINS NEST
jhinojosa
Brownsville TX
Posted: 06/28/08 04:05pm Link  |  Quote  |  Print  |  Notify Moderator
Try retracting it just a little to tighten the fabric. Hopefully this works for you. If I extend mine all the way until the motor stops, it'll sag even dry, the moment I roll it back a little it stretches very nicely.
2008 Jayco Jay Feather LGT 25F
2008 GMC Sierra SLT 2500HD Crew Cab Duramax/Allison
Big Katuna
Deland, FL
Posted: 06/28/08 05:06pm Link  |  Quote  |  Print  |  Notify Moderator
Don't roll the awning out so far. You want the seam about 11:00 o'clock instead of at 1:00 o'clock facing from the front. Having the seam towards the RV makes a V for water to gather in. You can also manually pull the rear side down with a rope, S hook and bungee cord to keep the dump feature (which doesn't seem to work very well) pull down. I would rather have a manual awning after having an electric.
My Kharma ran over my Dogma.
5weekendwarriors
iowa
Posted: 06/28/08 07:18pm Link  |  Quote  |  Print  |  Notify Moderator
This may seem to simple, but mine is under waranty right? So shouldn't I just take it back to the dealer and tell them to fix it. And that it's not dumping water like it's supposed to.
  • 2008 Dodge Ram 3500 Megacab Dually 6.7 CTD 68RFE 6 Speed Auto 3.73's
  • 2009 Keystone Sprinter 311BHS
  • Equalizer 12000# Hitch
  • 2007 Jeep Commander
  • 2004 Lowe Suncruiser 20' Pontoon
  • Gone But Not Forgotten
  • 2006 McKenzie Starwood 30CKS:2001 Jayco Eagle 304BH
JJBIRISH
Butler, PA, USA
Posted: 06/28/08 08:36pm Link  |  Quote  |  Print  |  Notify Moderator
that is exactly what I would do if it didn't work as advertised...
Hornet28BHDS
Parker, PA
Posted: 06/28/08 08:44pm Link  |  Quote  |  Print  |  Notify Moderator
I agree.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
