RV.Net Open Roads Forum: Travel Trailers: Power Awning Pictures
 > Power Awning Pictures
BarneyS
S.E. Lower Michigan
Posted: 07/02/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
firemedic16 wrote:
Has anyone tried to modify the awning with a small grommet, like you would find at the corner of a tarp ? I thought of putting this in the middle, near the deepest part of the pooling, and let water drain. It would stop the pooling, but cause a stream of water to fall into the " dry area " of the awning. I was thinking this might be better than retracting the awning during rain, and could provide some usable space under the awning during a storm.
Any thoughts ??
If you do that, make sure you have a big pot!
Barney
2004 Sunnybrook 30FKS TT
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Check out the new RV.net Blogs!
Visit our website here
Big Katuna
Deland, FL
Posted: 07/02/08 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
IF YOU DON'T RUN THE AWNING ALL THE WAY OUT IT WON'T POOL UP WATER!!!!
Like I said in my previous posts, if you run it all the way out then run it back in a few inches so the seam is on the outside of the roller, water rolls off the outside before you get a pool. If you run it all the way out, you make a little valley and water gathers and forms a pool which just gets bigger.
Look at the picture again.
I leave mine out in heavy Florida rains and it works fine.
I would still rather have a manual awning so I could drop it down as far as I want for better shade.
My Kharma ran over my Dogma.
Chad Brooks
Tifton GA 31794
Posted: 07/02/08 06:49pm Link  |  Quote  |  Print  |  Notify Moderator
I for one really like the electric awning other than the water dumping issue. Mine too has had water puddle on it and I had to push it off. IMO, you can't beat hitting a switch and watching your porch roll out. With a manual awning you have to use both hands which requires you to put your beer down. I will try not rolling mine out all the way as suggested. If that works, I will be golden.
2002 Ford Excursion Limited V10 4X4
2008 Flagstaff 831KRSS Classic Super Lite
-Equalizer
-Prodigy
Prior RV's
2005 Montana 3380RL 5ver
1999 Holiday Rambler 33RL 5ver
1996 Jayco 302FK TT
dbcc186
Massachusetts
Posted: 07/02/08 06:54pm Link  |  Quote  |  Print  |  Notify Moderator
DeutscheMan wrote:
The Carefree "Travler" flat pitch electric awning is just as bad as the A & E if not worse. Anyone who says they like theirs, has probably not used it much in inclement weather. In rain, the awning holds "gallons" of water before enough weight builds to activate the so called "automatic" dump feature. In reality, its more of a "collapse". All the water pours down at once. What used to be dry, is now wet from the waterfall hitting the ground. If it stops raining before it dumps, then the water stays on the awning causing it to stretch. If it freezes in the middle of the night, you have a giant ice cube. They are very sensitive to wind, and you have to take it in even in moderate breezes. Since it only has one pitch "flat" its pretty much worthless as a sun shade too unless you're on the equator and the sun is directly overhead. I really see no practical application for this design at all. Oh yea, it goes in and out with the push of a button. It must have been quite a song and dance routine to get the manfacturers to use these.
I am currently staying in N.H. and we have got some of the heaviest rain I have seen in awhile. I have a brand new Jayco with the Carefree Traveler. It does not have auto dump to my knowledge. So, I have used your basic BUNGEE cord. I hook one end to frame of awning where it attaches to the side of the trailer and the other to the middle of the extendable arm. I pull down on the arm and the piston in the supprt retracts. The bungee keeps it in place with a slight dip and I have had no problems with this MOD. Other campers have admired this. Works like a charm. I like my Carefree awning so far....
2002 Chevrolet 1500 4x4 Ext.Cab 5.3 3.73 rear
Putnam Class V XDR
Prodigy
2008 Jayco Jayflight G2 29BHS
MAXX AIR
Tornado
Reese Strait Line Dual Cam 1,200 lb Trunnion bars
FyrFytrDad
Gales Ferry, CT
Posted: 07/02/08 08:35pm Link  |  Quote  |  Print  |  Notify Moderator
DBCC Can you post a pic so we can see exactly where you hooked this up? Sounds like a viable option......
The only down fall of rolling the awning back a couple inches is that you automatically lose ANY pitch you had on the awning as compared to the top edge of the camper. I actually played with this idea a few different ways when scrubbing the roof on out 27BHSS and figured the pitch part out. Oh, and the motor does NOT have enough power to retract when there's much of a pool of water on the awning.....
1998 Ford Expedition
2008 Flagstaff 27BHSS
Camping nights in 2008: 21
dbcc186
Massachusetts
Posted: 07/02/08 08:58pm Link  |  Quote  |  Print  |  Notify Moderator
Yeah, I'll take a couple digital photos and try and post them.
firemedic16
Between Boston and Providence
Posted: 07/19/08 08:29am Link  |  Quote  |  Print  |  Notify Moderator
I posted this mod in tech issues. Here is the link to pics.
It is a simple 3/8" grommet hole in the deep end of the pool of rain water.
http://tinypic.com/useralbum.php?ua=Se7rwbz%2FoHLu16%2ByYPk9vg%3D%3D
Dixonmatco
Santa Rosa, California
Posted: 07/19/08 09:37am Link  |  Quote  |  Print  |  Notify Moderator
JJBIRISH wrote:
NOTE TO SELF...
NEVER BUY ONE OF THESE...
I'M WITH YOU!
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
Loopy
Western Pennsylvania
Posted: 07/19/08 09:51am Link  |  Quote  |  Print  |  Notify Moderator
I'm with everyone else who says not to roll it out all the way. We roll ours out then retract it about 4 inches. This pulls the awning tight and water rolls off the front edge this way.
Never had any issues with it.
Bryan , Jess, and our Parsons Russell Terrier, Melvin
1999 Chevrolet Tahoe 4D 4WD 5.7L 3.73" Rear End
Reese Strait-Line Dual Cam Weight Distribution Hitch
Tekonsha P3 Brake Controller
2008 Jayco Jay Flight G2 20BH and Mods
txtaco
Richmond, Texas
Posted: 07/19/08 10:46am Link  |  Quote  |  Print  |  Notify Moderator
There were 2 different types of awnings installed by Jayco. One that was flat w/the auto dump feature, and another that was a steep pitch version without the dump feature. The steep one was early on, and they then switched to the flat one. I heard they were exchanging the steep out to the flat under warrenty because the steep one was for 5th wheels and such with a higher roof. We have the steep one and I really like it. Just roll it back a couple of inches and the water just rolls right off the front, never had any pooling even in heavy rain.
2004 GMC 2500HD CC 6.0/4.10 4x4
2008 Jayco G2 32BHDS
