RV.Net Open Roads Forum: Hybrid Travel Trailers: Outside propane stove
Open Roads Forum  >  Hybrid Travel Trailers
 > Outside propane stove
Moose and Squirel
Arizona
Posted: 06/28/08 01:20pm Link  |  Quote  |  Print  |  Notify Moderator
We just bought a Travel Star 19ck. It came with the RVQ that attaches to the side of the trailer. Our old pup had a two burner propane stove that we liked much better. Anyone know if you can get one of these any more? All I seem to find is the RVQ grills.
Thanks!
jima53
Jacksonville
Posted: 06/28/08 09:48pm Link  |  Quote  |  Print  |  Notify Moderator
We also have the ck19 and have used the outside propane stove only once during our first season of camping with it. I'm not a propane stove kind of person and had problems cooking on it. Not sure about using it with the awning up. I have looked into buying the correct hose and another smaller 5 pound gas bottle so I can set the stove on a picnic table. Campers World has the parts needed to do this.
Jim
Chuck_S
Broadview Hts, OH, USA
Posted: 06/29/08 06:16am Link  |  Quote  |  Print  |  Notify Moderator
You could pick up a low pressure LP outside stove from any popup dealer, they're still fitting them to many of these trailers.
Your old high pressure stove (from some of the Coleman-by-Fleetwood trailers) won't work. I've tried. Even with the right connector it doesn't work.
-- Chuck
'06 Roo 23SS behind '07 Expedition out of Cleveland
Our Photo pages
Jon W
Omaha Nebraska
Posted: 06/29/08 06:30am Link  |  Quote  |  Print  |  Notify Moderator
Your high pressure stove will work on low pressure. I have been using mine for 4 years. It takes a little longer to get stuff hot because the flame is not as hot due to less gas pressure but it still works.
Chuck_S
Posted: 06/29/08 07:07am Link  |  Quote  |  Print  |  Notify Moderator
OK, you're right, but boiling a quart of water in 15 minutes as mine does fails my personal defination of "working,"
-- Chuck
nny12972
NY
Posted: 06/29/08 07:14am Link  |  Quote  |  Print  |  Notify Moderator
My MAGMA does a fantastic job both grilling and cooking---use it under the awning with no problem so far---I use the swing-arm boat-railing mount----gets it away from window and side of the TH.
J
pointbrze
Coltons Point, Maryland
Posted: 06/29/08 07:45am Link  |  Quote  |  Print  |  Notify Moderator
J
Got any pics?
Me- Cindy
DD- Stephanie
Sometimes DS- Mark
1 spoiled LhasaPoo- CoCo
2004 Starcraft TravelStar 21SSO
2003 Toyota Tundra V6
Pics
Leaf-Peeper
Small Town, USA
Posted: 06/29/08 08:03am Link  |  Quote  |  Print  |  Notify Moderator
We really missed having the high pressure outside stove that our Coleman popup had. The following pictures show how we added one to our Roo. There is a big difference in the performance between a high pressure stove and low pressure stove. There is also a big difference when it comes time to installing one or the other as well. There is much more work and materials needed to install the high pressure stove.
We really liked the high-pressure stove that came with our Coleman popup. Found a new one on ebay for short money for our Roo. Outfitted the stove using a piece of shelving board so that it has some counter space to either side.
Here’s the connection fitting on the camper side (#600 male).
Here’s the connection at the tanks. Each tank has one these modified (1/4” elbow) Marshall adaptors. Each tank is still connected to the low-pressure regulator/change over valve. The hose with the #600 female fitting has to swapped over to the other tank when the current one runs out. If the stove doesn’t light, that tells me that the changeover valve has swapped the tanks. I can reach through the holes in the tank cover to swap the stove hose over to the other tank.
Here’s the same high-pressure (16 psi) regulator that’s used on the Coleman/Fleetwood popup campers. The hose from the regulator to the tanks was made by MB Sturges Inc. for about $13 (1/4”mpt x 16” hose x 600 swivel female). High pressure LP flex line out from regulator to 3/8” soft copper underneath camper.
Here’s the stove stored behind the sofa inside the camper.
Sofa put down for better view of stored stove.
Stove removed. Velcro “loop” material against wall to protect surfaces. Bracket on right side made from old stove base. Hook & loop strap holds stove in place on left side.
'05 Chevy Tahoe & ’08 Rockwood Roo 23ss
'62 Myself
'62 Camper Honey
'96 Camper Twin Girls
Pictures of our '08 Roo 23ss on Webshots
Moose and Squirel
Arizona
Posted: 06/29/08 04:10pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks everyone, not sure my hubby's up to this mod. Why did the companies stop offering the high presure stove for outside? We never had a problem with ours.
cybervanner
Richmond, VA
Posted: 06/29/08 05:13pm Link  |  Quote  |  Print  |  Notify Moderator
I'd prefer to have an RVQ since I barbeque outside quite frequently when I camp. I currently have an outdoor stove, but would rather have an RVQ, since I can prepare food on the indoor stove easy enough.
