eestlane@sover.net
Wilmington, VT
What exactly does "side by side hookups" mean? No one, not even campground personnel have been able to explain.
outdoorsman2007
In the Woods - Somewhere!
It sounds like two campsites designed to have two RVs face different directions so that their awnings and front doors can face each other.
If thats not what it means - then I have no idea.
bldrbuck
Boulder, Colorado
A phone call to the campground should solve you problem. I was thinking of sites with units side by side along the hookups and the doors facing the opposite direction.
NCHornet1
Mt. Airy, NC.
These are also called "Buddy Sites" in some CG's and it is when folks are traveling together and want to camp with awning to awning. If in doubt call the CG to be sure.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
Jemc02
Central Ohio
Everyone is right...Side by side could mean that you will be awning to awning with someone or it could mean that you will be back to back with someone. Awning to awning allows you to buddy camp with someone and not have to run around one of the campers to get inside, back to back allows you to have a yard twice as big since there is no room between you and the person behind you. I have seen both setups so you would have to call the specific campground to see what their interpretation is of this idea.
downtheroad
Puget Sound
We try to avoid "side by side" hook up sites unless we are camping with close friends, because you will be very close to your neighbor. Sewer hose location can be "interesting" with this configuration.
GMC Duramax/Allison (LBZ)
Komfort 277TS Our Rig Pic
Reese Dual Cam HP
Hornet28BHDS
Parker, PA
outdoorsman2007 wrote: It sounds like two campsites designed to have two RVs face different directions so that their awnings and front doors can face each other.
That's what I was thinking.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
yardmaster
Levittown, PA
Thats what im thinking too...2 sites share a common power pole.
Scott B.
1986 Fleetwood Wilderness 23S
2004 Chevy Silverado 1500 - Cowboy Cadillac
JJBIRISH
Butler, PA, USA
its a common setup in many CG pull through's...
nothing wrong with it...
Love my mass produced, entry level, built by Lazy American Workers, Hornet
davidj54
South Alabama
Side by side means facing back to back and the site in front of you faces you. It's a great thing if you're camping with family or friends and can get the two facing each other.
Dodge Ram 2500 Mega Cab (Yeah, it's got a Cummins)
2006 Forest River Grand Surveyor GS-280
Prodigy Brake Controller
1000/10000lb Equal-i-zer with 4-way sway control
