RV.Net Open Roads Forum: Class A Motorhomes: please help,,, gen problems
 > please help,,, gen problems
bigjoep
louisiana
Posted: 06/29/08 09:46am Link  |  Quote  |  Print  |  Notify Moderator
99 HR Endeavor with 7.5 onan diesel
the problem is the gen will start and run fine but when i let go of the start button it kills.
any help would be appreciated
timebum
Westlake Village, Ca
Posted: 06/29/08 09:53am Link  |  Quote  |  Print  |  Notify Moderator
Do a search on this. This problem has been discussed hundreds of times.
Art
ole trucker
Westminster,MD. USA
Posted: 06/29/08 12:31pm Link  |  Quote  |  Print  |  Notify Moderator
Art, you could have answered his Q instead, sounds like the switch to me.
Wish I could help more. Good Luck
Will and Ina's Endeavor
LIVALIL
Nick Badame Refrig.
Cape May Court House, N.J.
Posted: 06/29/08 12:34pm Link  |  Quote  |  Print  |  Notify Moderator
I second the switch...
Grounded somewhere
Nick-
MCI 102C3 40' 2006' Bus Conversion by Atlantic Custom Coach
Detroit 475hp 8V92t w/Allison Ht750 auto
Master Mason, Cannon Lodge #104 S. Seaville N.J.
FMCA# F-27317-S
Norm Payne
Livingston, TX
Posted: 06/29/08 01:14pm Link  |  Quote  |  Print  |  Notify Moderator
When the engine dies you should get an error code - a series of flashing lights. Use the owners manual to see how to read the error code and it should indicate what the problem is.
Norm
2005 Dutch Star 4015, Cummins ISL 370 hp
2007 Honda CR-V
See Ya Down The Road
http://www.seeya-downtheroad.com
bisgaard
Alpine, CA, USA
Posted: 06/29/08 01:15pm Link  |  Quote  |  Print  |  Notify Moderator
My 7.5 has a similar problem as well, and searching this forum did not turn up any related help.
I assume you are using your dash or remote switch & there are no error codes, is there a way you can disconnect or isolate the switch? Then you could try the genset mounted switch & if it works, you've found the problem. If not, you haven't spent anything yet!
TJ & Cindy, FMCA F363139
04 National RV Tropical T370
350Hp CAT-C7 3000MH
07 Honda Accord 5spd toad
jauguston
Bellingham, WA
Posted: 06/29/08 03:38pm Link  |  Quote  |  Print  |  Notify Moderator
If the generator control box does not see AC output when you start it it will stop when you release the switch. Many reasons for no AC output but not likely a problem with the switch.
Jim
Jim, Sharon and Buddy the Yorkie
1999 Gulfstream Sun Voyager 31' ISB Cummins 210 uprated to 275
Trippe-Lite 1800w inverter 4-6v GC batteries
3- Kyocera 130w solar panels
1987 Suzuki Samurai tintop Toad w/VW 1.6 turbo diesel power
bigjoep
louisiana
Posted: 06/29/08 03:46pm Link  |  Quote  |  Print  |  Notify Moderator
its working now after playing with both swithes inside and out woking them back and forth, it must be one of them is going bad, thanks for the help.
bigjoep
louisiana
Posted: 06/29/08 03:47pm Link  |  Quote  |  Print  |  Notify Moderator
i appreciate your input. you put alot of thought into it.
rebel462
ontario canada
Posted: 06/29/08 03:49pm Link  |  Quote  |  Print  |  Notify Moderator
On my 6500 Onan Gen. just below the start switch on the Gen. is a plug you can disconnect it. This plug is for your remote switches in the motor home.
If the Gen. will start and run without the plug connected it will not be the Gens fault.There also is a breaker switch at the Gen. that you can turn off to let the Gen. start without a load on it.
Hope this helps.
