RV.Net Open Roads Forum: General RVing Issues: Ground fault problem
 > Ground fault problem
MGB939
Pawnee City, Nebraska
Posted: 06/29/08 06:19pm Link  |  Quote  |  Print  |  Notify Moderator
Lightguy48 is right,both out going and return juice MUST be equal, if not, the hot stuff is going someplace else. And this is what you don't want, GFI prevents this.
2001 GMC 2500HD Ext. Cab 8.1/Allison,4:10's
16k Drawtite Slider
Prodigy controlled
2002 293RKS Jayco Eagle
2- EU2000i Honda Gens.
2004 FLTHCU/I Harley-Davidson Ultra Classic
slowpez
columbia, sc, usa
Posted: 06/30/08 06:40am Link  |  Quote  |  Print  |  Notify Moderator
Sorry Jerry, phone calls are just not something I do although I know you mean well. The GFI on the CG post is what tripped. Of course, we can't test the outlet since we are not at the CG anymore.
Thanks for everyones suggestions but I suspect it is way beyond my powers and I will have it checked out by our RV repair service when we take it in to make sure that the problem is not with the 5er.
One thing I did notice on the outlets at the CG was a trip switch that was also on the 120 side. The yellow button on it flipped to red when we plugged the 5er in. The second CG we went to had the switch on the 120 but not on the 30amp outlet.
Again thanks for everyone's help and suggestions, Susan
Ray and Susan
2007 HitchHiker II 29.5 LKTG LS
2007 SD Ford F-250 Lariat 4x2 Supercab
6.0 L V-8 Diesel with Tow Command System
2 Old Folks with 1 Traveling Cat
http://picasaweb.google.com/slowpezrs
Airstreamer67
Pineville, LA USA
Posted: 06/30/08 09:06am Link  |  Quote  |  Print  |  Notify Moderator
I also don't ever remember noticing any GFIs on 30A or above circuits.
Are you sure your service wasn't affected for some other reason?
For example, my surge protector won't let me connect if the campground's nonGFI 30A wiring is somehow faulty, such as reversed polarity or a bad plug connection. I've run into such problems on a couple of occasions and had to move on.
