RV.Net Open Roads Forum: Truck Campers: Valve Stems
 > Valve Stems
J&S~B
Oceanside, CA
Posted: 06/30/08 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the information everyone. I'm leaning towards metal. I've had them in my 68 FJ40 for years with no leaks or problems. Now, the challenge is to find some of decent quality designed for high pressure.
GMC Sierra 2500 HD 4X4; Lance 815;
mrblaine
SoCal
Posted: 06/30/08 11:22am Link  |  Quote  |  Print  |  Notify Moderator
I do a lot of custom valve stem installs on rims with beadlocks to stop the rocks from eating up stems and have found these folks to have a good selection and quality.
http://www.myerstiresupply.com/default.asp
05 Dodge 3500 4x4 DRW Long Bed 4dr
07 Lance 992
III so far.
danewguy
LI, New York
Posted: 08/22/08 07:38am Link  |  Quote  |  Print  |  Notify Moderator
I have heard that these braided extensions that I have on my valve stems are also a cause for leaks, has anyone had this same issue? it appears that if not set just right they can put uneccessary strain on the valve stem causing it to rip over time. Is there a better alternative?
PS I have had a couple of tire failures and I am trying to nail down the causee between the valve stems and possibly being over weight
1999 31ft Gulfstream Conquest Class C
petekerwien
Camano Island, WA
Posted: 08/22/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
The only flat (knock on wood!!!)I have had was the one rubber stem I hadn't gotten around to repalcing yet.
 > Valve Stems
