RV.Net Open Roads Forum: Folding Trailers: Lost dust cap...should I re-pack bearings?
 > Lost dust cap...should I re-pack bearings?
DaveShay
Calgary, Alberta, Canada`
Posted: 06/29/08 04:32pm Link  |  Quote  |  Print  |  Notify Moderator
On my trip this weekend, I noticed when setting up that the dust cap on one wheel hub was missing. Must have come off as we were driving to the campground.
As the castle nut etc. is now exposed, should I re-pack my bearings or are they sufficiently protected by the nut from dirt getting in there? Can I get away with just replacing the cap?
Annoying, because I just did that job this spring.
Dave.
DaveT
2002 Chev Suburban
Rockwood Premier 2518G
Wife, 3 Kids, No Pets
dbbls
Missouri
Posted: 06/29/08 04:33pm Link  |  Quote  |  Print  |  Notify Moderator
If it were mine I would at least repack the outside bearing.
1999 F250 Superduty, V10 with Banks Power Pack
2004 Colorado 29RL 5th wheel with 3600 watt Onan
JUrban
Delaware
Posted: 06/29/08 05:41pm Link  |  Quote  |  Print  |  Notify Moderator
Clean and repack after CLOSELY examining bearings and cones, inner and outer. An hour or two's work now will keep you from a ton of grief on the road. Cheap insurance.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
othertonka
Stockton, CA
Posted: 06/29/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, pull both bearings, clean, examine and repack. The fine road grit or sand will act just like sandpaper.
Othertonka
2004 Southwind 32VS
2002 CRV Toad
U. S. Gear Unified brake system
Retired Fire Captain, SFD
AZJIM1
Phoenix, AZ
Posted: 06/29/08 09:22pm Link  |  Quote  |  Print  |  Notify Moderator
Went through this exact problem TWO years in a row . . . lost a cap while on a trip. Last year I lost it on the FIRST day of an 11 night trip to Yosemite/Sequoia. The funny thing was I fashioned a makeshift cap out of foil duct tape, which of course did not stick to the hub at all, but was still on the wheel when I got home . . . 2000 miles.
Anyway this year I bought brand new caps at our local RV parts place and had no problem on our 3400 mile trip to Yellowstone and Mt Rushmore a month ago.
1999 Coleman Westlake that replaced STOLEN!!! 1987 Coleman Sequoia
2006 Honda Odyssey
Me, Wife, Daughter, Son
A Pack (Two) of Australian Shepherds
MY MOD AND CAMPER PICS HERE
smkettner
Posted: 06/29/08 09:25pm Link  |  Quote  |  Print  |  Notify Moderator
Unless you were off on a very dusty road with dirt caked in the grease I would just slap a new cap on. The gease does not move that much to suck all the dirt in.
Bmach
Spfld, Ma
Posted: 06/30/08 10:17am Link  |  Quote  |  Print  |  Notify Moderator
IMHO I would just put on a new dust cap and not worry about it.
springoflife
Butler, PA
Posted: 06/30/08 12:12pm Link  |  Quote  |  Print  |  Notify Moderator
Wow! These responses are all over the map, from one extreme to the other.
If it were me, I would take the middle ground like DBBLS and focus on just the outer bearing and race.
DaveShay
Posted: 06/30/08 12:52pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the responses. Much appreciated.
I have now repacked both inner and outer bearings....probably didn't need to, but decided to err on the safe side as the job is not that bad.
I found out why the cap came off. I bought a replacement (surprisingly it was quite hard to find) and it is not a tight fit in the hub.
Anyone experienced this and have any suggestions? I will see if a slightly larger one is available, but I bet the next size up is too big.
Dave.
smkettner
Posted: 06/30/08 02:14pm Link  |  Quote  |  Print  |  Notify Moderator
Use a center punch to make some slight dimples in it.
