jojolou
S. E. Michigan
I'm thinking about having glass cut to cover the wood tabletop and also the wall credenza to protect the wood from scratching. Has anyone ever done this? I'm sure I'd have to wrap it and lay it on the bed to travel, but what other problems might I encounter?
Lou
2008 Allegro Bay 35 TSB W-25.5
Polishnurse
Schodack, NY
I don't think it's the way to go, but if you do go with the glass, make so it is tempered glass, cost a little more, but a lot easier to clean up, or you might consider safety glass. JM2Cents Bill
Jamesrpm
Oregon Coast
Sounds like more trouble than it's worth. Large heavy piece of glass to have to keep moving around.
___________________________________________
I plan on living forever , so far , so good
rooster
somewhere in the Ocooch
My glass tabletops scratch, so it would just be trading scratches to the glass tops. Sounds nice though.
Tony & Cam
1999 Tradewinds 7371
2001 Cherokee
Rich D.
New England
I would be worried that a loose sheet of heavy glass, even on the bed, could become a deadly missle in the event of a panic stop or accident. IMO, use the table as is, if it gets scratched repair or replace it.
Rich D. Wanderlodge LXi 43'
JerryofWV
Charleston, WV
You might consider an epoxy finish. You mix two parts together and pour it onto your table. It is about like thick syrup. You spread it out with a plastic card. It is like the tables in some restaurants.
I got it at Lowes.
Jerry & Dee Dee Pauley
1998 Pace Arrow 36S, 1 Slide, Tag Axle, Triton V10, Front Konis, Rear Track Bar, Banks Ram Air, 2000 Tracker Toad
The happiest people don't necessarily have the best of everything. They just make the best of everything they have.
jojolou
S. E. Michigan
Hmm - wish the tabletop would have been the same as the countertops like a lot of rigs have. Maybe I'll have to think on this a little more. When we took delivery of the rig last fall, I noticed the table had a little elbow swipe while the stain was still damp. Tiffin sent us a new tabletop, but I don't want it getting damaged. Thought a glass topper was the way to go. Let me know if any of you have other ideas. Thanks.
Mary Jo
Ozarkwoods
Bolivar, MO
JerryofWV wrote: You might consider an epoxy finish. You mix two parts together and pour it onto your table. It is about like thick syrup. You spread it out with a plastic card. It is like the tables in some restaurants.
I got it at Lowes.
I was just going to say the same, if you are worried about scratching the wood. This surface is quite durable won't slide around, break or become a projectile in an accident. Do be careful about any drips over the edge so have the floor and surrounding area protected.
Randy and Annie FMCA-371966
1996 Coachmen Destiny DP
300 Cummins CTA 8.3
6 spd Allison
Spartan Raised Rail Chassis
FROG 06 Wrangler Rubicon Unltd
Dollied 03 Toyota Corolla
xctraveler
Rochester, NY
How do you know a motorhome has been loved and used? Just look for the scars both inside and out. I try to avoid damaging stuff, but scratches and nicks happen when I am not looking.
I cannot imagine dealing with a a sheet of tempered glass every time I go to move. We sometimes travel 3 or 4 days in a week. One more set up take down item would be a hassle for us. Besides I am sure I would nick the wall as I move the glass to and from the bed. Bound to happen eventually. Clear epoxy coat will prevent scratches, but do you want to look like a chain restaurant.
Use care in your daily life and accept that the inevitable marks are really notches to show that you have really been using and enjoying your coach. If you are worried about resale you can always detail out the worst of the marks, but you still will be behind the curve on value, unless fuel goes to $2.20 and half the manufacturers are gone.
Paul
Trucking down the road in a 2004 Southwind 36E on Workhorse Chassis with a 2005 Toyota RAV4 AWD stick shift tow'd with US Gear Brake System. Check out my journal
FMCA 352081
sum1
So-Cal
Use a tablecloth if you're worried about it. They come in clear vinyl if you still want to look at the table. Easy to stow, as well.
