unionman
mn
Is there something you can plug in to your laptop to extend the range?
Enjoying the Lagniappe
Destin,FL,US
Yes, there are many. We use this one:
http://www.ccrane.com/antennas/wifi-antennas/super-usb-wifi-antenna.aspx
wtravlr1
Palm Harbor, Flordia, and Geneva-on-the-lake, Ohio
here is a wifi range extener
ang
2007 Forest River Sierra 31fkd (37') dual slides
chevy suburban 2003 2500-8.1 L.4.10's
prodogy/reese dual cam
rollgard springs
Fulltiming it since 2004. My only home.
My Homepage and Rv pics press here
Fulltimers
Anywhere, USA
Or you can go buy the latest technology in WiFi. It is the 802.11N. I had the opportunity to test this Wireless-N technology using a Linksys WUSB-300N WiFi card. I was amazed that it found 9 more WiFi routers in the area over my old card. You might want to wait a little while however because, although it is available, the Wireless-N technology in still in the Draft stage.
Fulltimers
Fulltimers Weblog
2003 Rexhall Aerbus 3550BSL
W-22 Workhorse
2001 Saturn SC2 (Mr. Toad
Photos
stevelv
FullTimers at Last!
unionman wrote: Is there something you can plug in to your laptop to extend the range?
There is nothing that you can plug in to extend the range of the built in wifi adaptor. You have to disable that one and plug in a seperate wifi adaptor - typically a USB device with the ability to add an external antenna to it.
There is a useful thread here
RV Park Finder
Fulltimers
2002 Beaver Santiam 38DST + Banks + 99 Jeep GC
DH,DW,Jake and Indie
Kamphiker
South Florida
Check out this High power USB adapter from ALFA
I use one at work and connect with a hot spot (since my work is to cheap to provide high speed internet) approx 1 mile from the office. I do use a 12 foot USB extender cable to place the ALFA adapter in the window. When I get the chance I am going to build or purchase a high gain antenna that can be added to this adapter since it has a RP-SMA threaded jack for a external antenna.
It also has the realtek 8187 chipset which works right out of the box for Linux applications such as Ubutu and Slax, Back Track Live Cd for Pentesting
I have 3 or 4 other external USB Wifi Adapters and by far this one kicks the other ones back to like using cheap kids walkie talkies for range and sensitivity.
GeeksRUs
Sundre Alberta
I use this Wi_Fire device: http://hfield.com/index.htm
Does a great job.
EH!
GeeksRUs
2008 Big Horn 3400RL
2003 F350, PowerStroke, 4x4, SuperCab, LongBox, SWB
RV Home Base @ Coyote Creek, Sundre Alberta
DaveMac
Citrus Heights, CA, USA
Just get an Airlink 802.11n USB adapter and plug it into USB port.
Turn off built in WiFi and hang adapter as high as possible with 6 ft. cable. Don't pay more than 20 bucks for the Airlink!
2007 FIESTA LX
TRITON V-10 & JEEP LIBERTY TOAD
3 TIMES RETIRED
CH. 13 "BLACKJACK"
MrWizard
Van Nuys, Ca
I use one of these http://www.dustydragon.com/wifi.htm
idea came from here http://www.usbwifi.orcon.net.nz/
mine
several people here have built one, they work very well.
Moderator's edit: Reduced the width of three pictures to the forum's recommended maximum of 640 pixels.
edited 07/02/08 08:37pm by an administrator/moderator *
Connected via Verizon Via LG VOYAGER VX10000
Maximum memory has been reached !
DaveMac
Hey MrWizard -- how did you determine the focal point on that contraption? If you did and mounted it on your batwing antenna for height and pointing you might get some pretty good results.
