RV.Net Open Roads Forum: How to:Attach Weber "Q" to quick connect on 5th wheel?
 > How to:Attach Weber "Q" to quick connect on 5th wheel?
jlvtx1800
Buffalo
Posted: 06/30/08 05:35am Link  |  Quote  |  Print  |  Notify Moderator
I have:
- A Weber Q-100
- Jayco 435 BHS with a quick connect propane connector for the optional grill
I am trying to find a 5' to 10' hose that can connect that has a mini propane connection on one side and has a quick connect on the other side...does this exist?
Thanks
- 2008 Ram Laramie MC 4x4 SRW 3500 CTD 6.7L 6 speed manual
- 2008 Jayco Eagle 345 BHS
MI Director
Michigan
Posted: 06/30/08 06:17am Link  |  Quote  |  Print  |  Notify Moderator
Check with your local propane store in your area to have one made or check Camping World.
jlvtx1800
Buffalo
Posted: 06/30/08 06:36am Link  |  Quote  |  Print  |  Notify Moderator
My question answered on another site.
http://www.myrvtalk.com/mods/1306-bbq-connected-lp-quick-disconnect.html
* This post was edited 06/30/08 07:02am by jlvtx1800 *
Hoops
Indiana
Posted: 06/30/08 07:40am Link  |  Quote  |  Print  |  Notify Moderator
We went to our local heating/air conditioning place, that also sells gas grills. They made us one with the correct connection. Wasn't very expensive, less than $15.
The Hoops. ED and Becky
Missy our little Bichon
2004 F350 V10
2005 Jayco Legacy 38RDQS
javaseuf
Southern Cal
Posted: 06/30/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
You do know that the Weber Q will NOT work connected to that low-pressure gas supply unless you remove the internal regulator on the grill, don't you?
The Q has an internal regulator and if you use it on a low-pressure trailer connection, you will get a very small, unuseable flame.
There is more to using a grill designed to take the small bottles than just getting a hose and connecting them to the Rv's low-pressure propane outlet. It doesn't work.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
jay2003
San Joaquin Valley, California
Posted: 06/30/08 10:12am Link  |  Quote  |  Print  |  Notify Moderator
Very true since you would be double regulating the flow.. once at the bottles and once at the grill. Your best bet is to connect directly to one of the bottles with this type of grill. They make hoses for that purpose. I posted a few weeks ago regarding those hoses as some from CW were said to have problems specifically with the Weber Q series grills. I broke down and bought one directly from Weber instead that is said to specifically work with the Baby-Q (Q-100) series grills. Paid a little more for it but I didn't have to worry if it was going to work or not.
05 Toyota Tacoma DC 4x4 SB Off-Road Package w/Tow 128" WB
2005 KZ Jag 24JB*Newer Model Floorplans Slightly Different
Prodigy Brake, WD hitch, friction sway
Garmin GPSMAP 60CSx
Honda EU2000i Generator
Me.. the wife, the 5 year old, and the 2 year old
