RV.Net Open Roads Forum: Tech Issues: Small 12v Fan for Norcold Refrigerator
 > Small 12v Fan for Norcold Refrigerator
SamG
Trabuco Canyon, CA
Posted: 06/30/08 03:16pm Link  |  Quote  |  Print  |  Notify Moderator
SweetLou, I beleive, is talking about a fan INSIDE the fridge for circulation, right?
It's my understanding that a fan outside the fridge, pushing air up out the exhaust will also help the unit work better? I've seen those little battery operated ones for inside the frige, but never considered hardwiring something. I can see how it might be hard to find power in there?
Sam G.
canusa
hanwell, new brunswick, canada
Posted: 07/01/08 04:27pm Link  |  Quote  |  Print  |  Notify Moderator
I found my power in the outside fridge compartment and then brought the wire in to the fan where the temp sensor ( fine copper pipe) comes into the back wall of the fridge. Mine ,a dometic, just had gum seal around that hole and it was easy to pierce it with the new wire and then pull it thru from the inside of the fridge. I used a very small 2" o.25 amp computer fan and it seems to do an adequate job. I have it switched and only run it when it is warm out. Also have 3 2.5" computer fans mounted as a bar in the exhaust stack--blowing up at the finned cooler. They really help when it gets into the high 80's or 90's.
Cheers!
Herb
04 dodge cummins
03 northstar adventurer 8.5
reeeetired!!
kneal44
EAST CENTRAL TEXAS
Posted: 07/05/08 09:24pm Link  |  Quote  |  Print  |  Notify Moderator
i got my fan from a discarted computer . fan uses .070 amp. added a switch incase i want it off. at the lite fixture looked for a wire that was hot all the time , weather door was open or shut. assembled some brackets and mounted over the aluminum fins. works good. and was free.
when u play in the sand .... you can get stuck
9-24-08 corpus christi padre island texas. wrecker had to haul me out!
'92 dp 5.9 cummins 190 hp....8mpg yuck!
wny_pat
Western NYS
Posted: 07/05/08 11:10pm Link  |  Quote  |  Print  |  Notify Moderator
You could always get one of the battery (d cell) operated fans and just set it inside the frig. They run a long time on just 2 D cell batteries. Any RV store should have them. Or you can get fancy and get a computer fan and find 12 volts to connect it to.
