RV.Net Open Roads Forum: Travel Trailers: Keeping Sewer Hose Off The Ground
 > Keeping Sewer Hose Off The Ground
GASA765
San Diego Ca
Posted: 06/30/08 07:30am Link  |  Quote  |  Print  |  Notify Moderator
Just wondering what everyone uses to keep the sewer hose off the ground. We have one of those accordian type stands, but it didn't work to well this weekend on uneven terrain, and we're looking for something more stable.
Thanks!
Gary, Serena, Monte(JRT), Roxie(Long Hair Dachsund) Haylee(Goldie Mix)
2004 Fleetwood Terry 270FQS
popscolly
North Carolina
Posted: 06/30/08 07:37am Link  |  Quote  |  Print  |  Notify Moderator
Have seen a half PVC pipe contraption. It expands so it's easy to store. Can't remember where I saw it. Could be that CW carries it. Still using the accordion type myself and don't have any problems with it.
The Colliers, Michael and Linda
2000 Gulfstream Innsbruck 30 FKD
2003 Ford F150 Supercrew Heavy towing
Chase, Swayze (Tibetian Terriers)
and Byshe (Papillion)
Hornet28BHDS
Parker, PA
Posted: 06/30/08 07:58am Link  |  Quote  |  Print  |  Notify Moderator
We use a Sidewinder for our hose and it works well.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
pammi
Westland, MI
Posted: 06/30/08 08:16am Link  |  Quote  |  Print  |  Notify Moderator
Somewhere on this forum I saw where someone mounted a square PVC fence post to their bumper and inside it they had a 4" pipe sawed in 1/2 lengthwise that the hose nested in. They used the lengthwise piece to lay the hose in from the sewer output on camper to the inground connection. Wow, was that a convoluted explanation or what
2004 Rockwood Roo 23B (new to us)
2006 Nissan Xterra
When we camp, it's DH & me mostly. Occasionally step-daughter (16) comes, though not necessarily her choice
Rollincool
Always Rollin
Posted: 06/30/08 08:42am Link  |  Quote  |  Print  |  Notify Moderator
If we have a site with uneven terrain, then I just lay the hose on the ground. Otherwise I use the sidewinder support.
2008 Chevy Silverado 4x4 3500 RC/LB 6.0
2007 Chevy GS Conquest Super C 6340DK
2007 Chevy HHR Toad 2LT 2.4
1990 Chevy G20 Cargo Van 305
1967 Chevy Camaro Pro Street 468/650hp BBC
My 70's Show - Tom Kent Radio Network - KLTH - K•HiTS 106.7
swebber
Brunswick , MD
Posted: 06/30/08 08:54am Link  |  Quote  |  Print  |  Notify Moderator
I use the CW knock-off version of the Sidewinder support. I also use plastic rain gutter sections to hold the hose in long straight runs.
Buy a piece of Vinyl rain gutter, cut in half and then on one half take of about one inch of both sides. The shortened piece will now slip inside of the other half and will let you support the hose easily.
Sorry but I have no pictures of this yet.
Steve & Tracy Webber
'07 F250 6.0 PSD LariatFX4,AirLift,Edge Insight
'07 Jayco Eagle 314BHDS "The Cramalot Inn II"
ReeseDCHP,Atwood 3500#,FlushKing,WeberBabyQ
Our Pic's
We do not stop playing because we grow old, We grow old because we stop playing!
AVid
SE Michigan
Posted: 06/30/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
I use a PVC gutter. It comes in 10' lengths. Cut it in half and trimed the edges off of one piece so that it slides into the other. When expanded it is 10' long.
webhannet
Southern Coastal Maine
Posted: 06/30/08 09:13am Link  |  Quote  |  Print  |  Notify Moderator
I don't get it either! People get really worried about these hoses, and the different support arrangements mean "just one more thing" to set-up, clean and store. My one concession to the "sewer hose obsession" is the belief that they can't be throughly rinsed - and I replace them often.
I just lay mine on the ground and let gravity do its work. I prefer to let the dips form a sort-of "trap" to stop sewer gas from coming up the hose and adding to what might already be coming out of my roof vent - and blowing near my fantastic fan - into the living area.
Keith99RS
Suffield, CT
Posted: 06/30/08 09:28am Link  |  Quote  |  Print  |  Notify Moderator
Directions for the "Slunky" branded support says to put a slight droop at the TT end to act as a P Trap to prevent gas entry. Your fantastic fan should be drawing air out of the TT not in. At least mine does. Pulls hot air, mosit air from showers, or odors out and fresh air in through the TT's doors and windows like a whole house attic fan. I am amazed at how much air my littrle fan moves!
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
jdkd123
Northeast
Posted: 06/30/08 09:47am Link  |  Quote  |  Print  |  Notify Moderator
Kinda agree here....never really seen the need to keep this sewer component off the ground. It's a dirty sewer hose....and gravity has always worked for me. JMO
JDKD123
2005 Coachmen CONCORD
GO SOX!
