RV.Net Open Roads Forum: Dinghy Towing: towing jeep liberty
Search only in Dinghy Towing
 > towing jeep liberty
phxspice
phoenix
Posted: 06/30/08 10:35am Link  |  Quote  |  Print  |  Notify Moderator
Hello All,
I am moving in 19 days and need to tow a Jeep Liberty behind a Penske moving truck. When inputting info into their web site it says that it cannot be towed due to tire size...
Has anyone ever done this?
Do I need to purchase my own tow dolly?
Thanks in advance for advice!
jimdoreen1
El Cajon Ca
Posted: 06/30/08 10:43am Link  |  Quote  |  Print  |  Notify Moderator
I am interested in purchasing a new jeep liberty to tow behind our motorhome. I thought the liberty can be towed 4 down, with tow dolly. I guess I need to look into more. anybody have any input.
phxspice
phoenix
Posted: 06/30/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
Jeep says it can be towed, maybe it is just the self mover trucks that have a problem? I have seen them being towed behind RV's before.
STINGRAYRVMAN
PANAMA CITY
Posted: 06/30/08 10:50am Link  |  Quote  |  Print  |  Notify Moderator
phxspice is wanting to tow a libert on a 2 wheel dolly 1 time. jimdoreen1 you ar talking about towing it with a towbar set up which the liberty is great for.
Penseke is saying it won't work because of tire size because the straps that come with their dolly's are made to go over smaller automobile tires. phxspice needs to put his libert on the 4 wheel flatbed trailers rather than a 2wheel dolly.
TXiceman
(Near) Houston,TX
Posted: 06/30/08 10:53am Link  |  Quote  |  Print  |  Notify Moderator
If there is any question, rent a trailer to haul the Jeep. Not all Jeeps can be towed 4 down.
Ken
KE5DFR
Vintage 1979 Silver Streak Supreme Rocket toted by a 2002 F350, crewcab dually, 7.3L,4.10 axle,SCMT. Travel with two miniature Schnauzers and one African Gray parrot. Practicing for retirement!
BarneyS
S.E. Lower Michigan
Posted: 06/30/08 01:04pm Link  |  Quote  |  Print  |  Notify Moderator
Moved to Dinghy Towing forum from Towing.
MH4Two
Ickesburg, PA
Posted: 06/30/08 02:22pm Link  |  Quote  |  Print  |  Notify Moderator
Almost all, if not all, Jeeps can be towed 4 down.
Almost NONE of them, can be towed with front wheels on a Dolly.
In order to tow 4-down, you will need to install a baseplate to attach a the towbar to, and unless you intend to tow the Jeep behind an RV in the future, it seems like an expensive and time consuming option.
I think you best bet is to rent a flat trailer and put the Jepp on it for a one time move.
Me, the DW, 2 dogs and more.
1998 Overland Larado, 41', one slide, 325 Cummins, '02 Jeep Liberty Upgrades we've done: SMI-Air Force 1 towed brake system, replaced all 3 TVs with new hiDef LCDs, inst. Xantrex 2Kw Inverter, Prog. Ind. HW50 surge protector
DarkRubiTJ
Livingston, Tx.
Posted: 07/01/08 06:27am Link  |  Quote  |  Print  |  Notify Moderator
With the advent of newer models and differences in drivetrains, not every Jeep can be towed 4 down. In fact the number that can be towed 4 down is dwindling every year. There are even 2WD Wranglers out there that can't be towed 4 down. If it's 2 WD it probably can't be towed 4 down WITH Chrysler's blessing.
Recently, of the three major truck rental companies, only U-Haul told us that we could tow our 4 WD 2008 Wrangler behind their trucks 4 down. Budget told us that we have to use a dolly, like that's going to happen. Penske told use that we couldn't do it at all. Point is, those guys don't have a clue, either. Do your research, read the owners manual and tow it the way Chrysler says is correct.
