RV.Net Open Roads Forum: 2007 Travel Star 21SSD slide out not working
 > 2007 Travel Star 21SSD slide out not working
ThumperEXC
Crested Butte, Colorado
Posted: 06/30/08 03:05pm Link  |  Quote  |  Print  |  Notify Moderator
Went out to get ready for a camping trip and the rocker switch didn't produce any results, not in or out. So I took off the kick panel on the sofa to access the motor and used a voltage tester to see if I was getting any power to the motor, answer was no. Moved to the switch, no power. Checked the fuse, it was fine. Went outside and crawled under to where all the wiring runs along the axle, no power. I'm far from handy when it comes to electrical problems. I had the trailer plugged in, every single other thing works except the slide out. Did I miss something? Could the wiring to the slide out some how have got disconnected to the breaker box? Any ideas? Thanks.
2004 F150
2007 Yamaha Grizzly 700
2001 KTM 520EXC
You can't take the Fisherman out of this Camper
Ontario, Canada
Posted: 06/30/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
It will not have a typical small plug in fuse. Look for a circuit breaker. It should look like: this
1960's: Tents.. 1970's: Soft top & Hard top P/U.. 1980's: 17' RV.. 1990's: 24' RV.. 2000's: FINALLY... 2002 Cougar 276EFS; 2002 GMC 2500HD Ext Cab 4x4; (Nfld/Labrador-Yukon/NWT/Alaska-Gaspe', Que./Florida!!)
ThumperEXC
Posted: 06/30/08 04:08pm Link  |  Quote  |  Print  |  Notify Moderator
Hmmmm.... didn't see any thing like that on the panel, but I'll look again when I get home, thanks.
Ontario, Canada
Posted: 06/30/08 06:12pm Link  |  Quote  |  Print  |  Notify Moderator
It won't be on the panel either... try to follow the cables coming from the battery and going to the slide motor. Once you find it, try connecting the two posts with a jumper and then operating the switch. If it's the breaker it may need to be replaced. Not all of them are resettable.
