RV.Net Open Roads Forum: Fifth-Wheels: Ride improvement advice needed
 > Ride improvement advice needed
gary085
NJ
Posted: 06/30/08 06:13pm Link  |  Quote  |  Print  |  Notify Moderator
Just returned to NJ after picking up our new 33' Cameo in FL. Since we are new to 5th wheel towing we didn't know what to expect ride wise. Needless to say, the DW is not happy. SC is the absolute pits on I 95 due to the expansion joints. Had a Trailer Saver air hitch installed while picking up the 5er and it helped some. Where do I go next? Truck is an '08 Dodge 3500 CTD dually long bed. The complaints are harsh ride and porpoising.
Some of my options, I think, are:
air suspension on truck
different shocks on truck
shocks on trailer (it has none)
More Ryde suspension on trailer
I don't want to start throwing $$$ at this situation when, hopefully, some of you out there whth experience can send me in the right direction.
weekendrvers
Iowa
Posted: 06/30/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Hi I am not sure but if you are talking about Chucking which can be caused by the expansion Joints ~`We Put on a Moyr Ryd pin box hitch and eliminated the problem~`The chucking made my tummy very sick~~~Sandy
New Everest Owners~~~
Steve, Sandy, Katie and Our Cocker DJ
Loving our Everest sweeeeett!~~
2007 345S
suesodyssey
SC
Posted: 06/30/08 06:33pm Link  |  Quote  |  Print  |  Notify Moderator
Gary, the Mor/Ryde pin box will almost eliminate all the chucking you are experiencing. We have a Freightliner, heavy Carriage with Mor/Ryde IS and the Mor/Ryde pin box. Smooth all the way, even on I-80 and I-10. I-95 almost all the way up and down is bad, but the Mor?Ryde pin box saves the day.
Sue & Bob Millar
2006 Carriage, 378
2004 Freightliner
Seeing our beautiful country, one state at a time.
donhov
near Jackson Michigan
Posted: 06/30/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Another place to spend a few dollars is to go to the EquaFlex spring hangers. It will help smooth out he ride considerably and with the wet bolt kit increase the life of the spring bushings etc. Also it might be how you are loaded, try adding, removing water in the fresh tank and even see how your trailer is loaded. Usually a little more weight in the front helps smooth the ride but not always.
* This post was edited 06/30/08 09:16pm by donhov *
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
bobpitzer
florida
Posted: 06/30/08 07:04pm Link  |  Quote  |  Print  |  Notify Moderator
I pulled my 41' Cardinal from Oh. to Fl.with 3/4 ton GMC crewcab shortbed.It porpoised quite a bit.Installed airbags as helper springs.Towed to Me. and was surprised at the improved ride.Truck carried the load much better.Came thru SC on way here & agree thier roads are rough,but Maine has them beat.Even diesel pusher folks complain about the roads here.Good luck.
cabanaman
middleburg florida
Posted: 06/30/08 07:16pm Link  |  Quote  |  Print  |  Notify Moderator
The airbags on my truck really took the jars out of the ride.Made it springier if that's a word? Already had equa-flex from the factory.
Retired Navy
2007.5 Dodge Ram SLT sport 2500 quad cab 6.7 cummins,6 speed auto with exhaust brake.
2007 Open Road 378SA4S-5 quad slide.
sele
illinois
Posted: 06/30/08 07:50pm Link  |  Quote  |  Print  |  Notify Moderator
We just installed the Mor Ryde pin box and can't believe the difference also try balancing your load or shifting you load first forward and then back. I found that having a full tank of fresh water helps the ride considerably but my fresh water tank is at the very rear of our f'ver. Part of it will be finding where you receive the best ride verses how much pin weight, But again I can't say enough about the Mor Ryde pin Box. WE WILL NEVER BE WITHOUT ONE AGAIN. It probably took out better that 75% of the rough ride.
scott
luvglass
Milwaukee
Posted: 06/30/08 08:43pm Link  |  Quote  |  Print  |  Notify Moderator
We have a Cameo also and are not experiencing your problems. We have the Mor Ryde pin box and RE trailer suspension. Also our 06 came with shocks.
The pin box should stop the chucking.
Fred Wishnie
2006 Carriage Cameo 35KS3, 2006 Ford F350 diesel dually, fulltimer
See our blog at http://www.mytripjournal.com/wanderingwishnies
“If all you ever do is all you’ve ever done, then all you’ll ever get is all you ever got.”
sirdrakejr
Las Vegas, Nevada
Posted: 06/30/08 09:19pm Link  |  Quote  |  Print  |  Notify Moderator
For some the spacing of the expansion joints match the spacing of the wheels on the tow vehicle and the trailer. There in not much you can do when that happens except to slow down until you are beyond that particular road. I use Timbrens ( http://www.timbren.com ) on my Dodge and it helped the ride a lot but expansion cracks are the bane of RVing.
Frank
RV.net blog
For those of you looking for expert advice, here ya go!
Frank
boatsplus
plymouth,mn
Posted: 06/30/08 10:00pm Link  |  Quote  |  Print  |  Notify Moderator
Gary, I too have been thrilled with Mor/Ryde on a previous coach. I now have Trail Air front and rear on a 37' Holiday Rambler. Sweet ride and seems to like the expansion joints too.
you could not go wrong either way,
boatsplus
2006 F-350 6.0 Lariat FX4 CC SB TP PP Draw-Tite 18K.
2008 Holiday Rambler Presidential Suite 37 Trail Air.
2007 Polaris Sportsman 800
2005 Polaris Sportsman 800
2002 Polaris 600 XCSP
