jamesla
Anderson Ca.
Our 5th wheel has what appears to be a vynal wall covering on
the inside walls. There is an overlay about 6 in wide of a contrasting material. This wallpaper like material is starting to peel off in certain areas. It has a sticky glue like substance
holding it to the walls. I think I will need another type of glue.
Any suggestions? Regards, Jim
03 F250 6.0 PSD
04 Komfort 22FS
newk
Gillette, WY
I've never tried it with self-sticking wallpaper, but I'm wondering if plain old wallpaper paste wouldn't work. At least it would go on smooth and be easy to clean up.
donhov
near Jackson Michigan
On our Cedar Creek when the accent stripes began to cone loose I could not get them to stay up. someone on another site suggested using a warm iron and tried a few non visable places and it worked well, nothing came back loose. You might try someplace that isn't very visable and see if it works for you. Be careful and don't get the iron too hot and melt the paper, just hotter than warm and gradually turn up till it begans to stick.
2003 Cedar Creek 30RLBS
2007 Dodge 5.9 Cummins Turbo Diesel 325hp/610Tq
4x4 3.73 axles short bed
Inferno Red W/Gold pinstripping
Trailering Texans
Huntsville, Texas
Elmer's ????????????
slotsavegas
Fort Worth
Had the same problem with a prior unit of mine. Texas sun caused it to peel. I found that a spray can of 3M adhesive worked best for me. I sprayed it on the wall board and then used a paint roller to smooth the covering back in place. Be careful not to spray on the wallpaper as it will cause it to melt (soften) and stretch as you re-apply.
Barbilou and Fujimo
St. Cloud, Minnesota
I used a hair dryer and peeled it all off.
Full Time since November 05!
'04 Cherokee M315L 2 slides Fifth Wheel
'05 Chevy Silverado 2500 4X4 Duramax Diesel,crew cab,long bed
Eliminator ELM-3600SS generator
Barb's RV Dreams Articles
Screamingeagle
Pennsylvania
Get the adhesive for vinyl wallpaper borders. It`s a different glue than regular wallpaper paste.
Screamingeagle
2008 F450 Lariat
2008 Big Sky 340RLQ
Drew and Judi and the boxer boys
jamesla
Anderson Ca.
Thank you one and all. I will try the iron first, and go from there.
Regards, jim
D&Sluv2fishandcampMN
BP Minnesota
I had wrinkles in my wallcovering so I tried the iron on it tonight. It worked great and smoothed the vinyl out very nice but one word of caution. Try it on the lowest setting on your iron first. You can always dial it up if it doesnt work. I had mine too hot and it instantly melted the wallcovering the first time I touched it. I tried it later on the lowest setting after the iron had a chance to cool and it worked great.
Our Camping History:
Variety of tents
'72 Lionel pop-up(SOLD)
Back to tent
'76 Dodge Jamboree MH(SOLD)
'98 Sportsmen 28' TT(SOLD)
Back to tent
'76 Dodge Jamboree MH (Bought her back)(for sale)
'93 Coachmen Catalina 23.5 ft 5th wheel
