RV.Net Open Roads Forum: Tow Vehicles: For the GM'ers about air filter indicator...
Search only in Tow Vehicles
 > For the GM'ers about air filter indicator...
NickG
Warren, Michigan
Posted: 06/30/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
That plunger that is on the air filter housing. Its supposed to show the red/orange part as the filter gets dirty.
I have had 4 gm trucks in a row and I've never seen the red. It has always been green.
At 54,000 miles, I decided to change the air filter today on the van as I was doing some other things to it. Even though the indicator was green, the old filter did seem dirty with noticeable more darkness at the point where the air enters the housing.
I'm wondering if I wasted $40 and should've waited for the red to show, or if this was something many others would do with the original filter past 50,000 miles.
2004 2500 GMC Savanna 6.0 / 3.73
2001 Mallard 30E
Wife,
Triplets born 10-14-02 (2 girls, one boy)
Older daughter born in 1985
Choc lab named Kia (No, NOT after the car!)
http://mywebpages.comcast.net/babies3/index.htm
NickG
Warren, Michigan
Posted: 06/30/08 07:38pm Link  |  Quote  |  Print  |  Notify Moderator
Also checked the trans fluid. Looked and smelled like you could put it back in the bottle and pass it off as new. I was wondering if that should be changed anyway with a filter too.
Engineer9860
Eagle Scout dad
Posted: 06/30/08 07:49pm Link  |  Quote  |  Print  |  Notify Moderator
The filter minder has been used on all OTR trucks for years.
Any restriction that pulls in the plunger any at all, is a negative pressure that is robbing you of airflow into your engine.
My golden rule for filters, and lubricants is....You can't change them too often. Or in simpler terms, there is no minimum mileage at which you can change it.
2002 Chevy 2500HD 4x4 8.1/ZF6sp RC/LB
2001 Chevy 2500HD 4x4 6.0/4L80E EC/SB
1997 Chevy Blazer 4x4
1994 Chevy K-2500 4x4 C6P 5.7/4L80E
1979 Chevy K-30 4x4 4sp 4.10
1977 Chevy K-30 4x4 4sp 4.10 454
30 year student of the Boeing B-17 Flying Fortress
92DakotaHD
Indiana
Posted: 06/30/08 08:00pm Link  |  Quote  |  Print  |  Notify Moderator
My uncles is red, doubt it's ever been changed in 4 or 5 years. I tried to reset mine with a new filter and can't get it to reset. Any pointers?
1992 Dakota 2WD 5.9L V8 (NOT Stock)
Headers, FMS Injectors, Ported TB, MP PCM (not good for towing),
2005 Chevy Tahoe Z71- Bermuda Blue, A/T Revo 265/70 "E"
Prodigy Controller
08 Passport 24RB, YAY SPACE!
Gone Racing!
A newbie, any tips please share!
M GO BLUE
Southgate, MI
Posted: 07/01/08 05:43am Link  |  Quote  |  Print  |  Notify Moderator
I tend to take out and clean my K&N air filter about every 5000 miles...
ERIC & BEV
2005 Chevy Silverado 3500 dually CC/LB Duramax/Allison
2008 Jayco Designer 35RLTS fith wheel
Built-In Onan 5500W generator
silversand
Montreal
Posted: 07/01/08 07:18am Link  |  Quote  |  Print  |  Notify Moderator
Air filter:
Do as Engineer suggests. I change our unit every 1.2 years regardless of indicator (however, we do only 5000 miles max ave. a year).
Tranny fluid: follow your owner's manual. If you are using your truck as in 'severe duty', change it out as indicated; if you are using your truck 'regular duty', do the smell and blotter test, and if this analog indicator shows negative, change it out. Otherwise, if analog test proves good change it out as per manual.
Cheers,
Silver-
Silver
Highbeam
Buckley, Washington
Posted: 07/01/08 02:52pm Link  |  Quote  |  Print  |  Notify Moderator
I've never had a gas engine'd GM pull that filter minder into red. I think they are fake. I've put 140,000 miles on my GM pickup and never saw that thing move. A diesel consumes much much more fresh air since there is no throttle plate.
1998 Chevy ECSB, K1500, 5.7 V8, AM trans temp and vacuum gauges. Scangauge. HD light harness with 4hi. Timbren overloads. 168,000 miles.
10,000# GVWR EQ trailer
1995 Nash 25' bunkhouse TT
10,000# GVWR EQ trailer with 4500# tractor, yep, 7000# trailer.
Strawfoot
Flagstaff, AZ, USA
Posted: 07/01/08 03:28pm Link  |  Quote  |  Print  |  Notify Moderator
Just had my air filter changed a couple days ago. It was reading in the green but my mechanic decided to check it out. Turns out you are right, the indicator means little. Mine was a mess and needed to be replaced.
Strawfoot
ktmrfs
Oregon
Posted: 07/01/08 10:59pm Link  |  Quote  |  Print  |  Notify Moderator
Normally on my duramax the indicator is still green at 15K miles when I change filter. (6.6 Duramax/Allison) However, one summer when I drove lots of dusty roads, it turned red in about 7K miles, I reset it to see what would happen, and a few days later it was red again, so I guess it works. I suspect that if you never get on the throttle for any length of time it may be pretty dirty and not turn red, since it looks at pressure differential and max pressure differential will be at or near full load WOT max RPM.
Cox89XJ
Tennessee
Posted: 07/02/08 01:06am Link  |  Quote  |  Print  |  Notify Moderator
I changed my 03 Chevy at 36k and again about 76k. It looked like it could have went longer, but was fairly dirty. I played with the red indicator with my mouth to see if it would work. It will work doing that, but I've never seen the red from natural use.
