Was told at Camper World that the hitch could not be removed on the Domani,there fore I could not install a 5th Airborne...anyone else run into this? Thanks
Camper World probably doesn't know which pinbox to order so "it can't be removed" or there is no corresponding model from Fifth Airborne that will fit.
Since the Domani can be ordered with a Morrhyde pin box, I'd give Carriage a call and find out which Morrhyde model to order. It will work better then the Fifth Airborne any day.
If you have the proper equipment, you can install these yourself. You'll need a friend to help with the lifting, a set of wrenches and sockets, and a torque wrench.
Carriage Cameo 33CKQ | 08 GMC 3500HD CC LB Duramax Dually | Sam the Cat and the Labs | Best wife going
