RV.Net Open Roads Forum: Travel Trailers: Lights "dim" when air conditioner comes on??
 > Lights "dim" when air conditioner comes on??
polecatlarry
Full timers with NO home base..we like it that way
Posted: 06/30/08 09:29pm Link  |  Quote  |  Print  |  Notify Moderator
Lately when our air comes on, we have noticed that our lights dim (quite a bit)..our voltage meter shows no voltage drop when this happens...the lights stay dim from 5 to 10 seconds before returning to normal brightness. Any ideas??? Thanks...
bldrbuck
Boulder, Colorado
Posted: 06/30/08 09:51pm Link  |  Quote  |  Print  |  Notify Moderator
If you are plugged in to shore power the the Air Conditioner is pulling down the 115 volt for just a bit. That lowers the input to the converter and in turn that lowers the 12 volts for a few seconds. The time is too short to see on a meter.
BlackSilver
East of Heaven, North of Hell
Your voltage meter probably isn't real sensitive.
The dimming lights result from IR-induced voltage drop on your AC power supply due to the current surge when your A/C compressor and fan both come on line.
It's a normal condition, more common if your park runs long supply lines or if you are hooked up to 30amp service and the A/C consumes a major fraction of those amps at startup.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
smkettner
Posted: 06/30/08 10:24pm Link  |  Quote  |  Print  |  Notify Moderator
Are these 120 volt bulbs or 12 volt bulbs that are dimming?
Rvndave
Medina, Ohio
Posted: 07/01/08 03:05am Link  |  Quote  |  Print  |  Notify Moderator
As the a/c compressor starts it draws a lot of extra current. You might try adding a Supco SPP6 superboost. This is a relay and start capacitor, this allows the compressor to start using much less power. Connecting the superboost is an easy two wire connection to the compressors run capacitor. Any air conditioning supply house or HVAC service department should have these in stock.
2003 Jayco 308fbs eagle 33' tt, towed by a 2003 Ram 3500 slt, quad cab dually, cummins diesel ho, trailer towing package, with 6 speed manual. Hauls better 1/2, 3 kids, myself, and a 2003 ez go clays car.. I have added so far, neon lights, clearance lights, back up lights, black light, lift kit, mud tires, and everything necessary to make the golf cart street legal. It's now ready to spend the winter in the garage for more mods. More neon, strobe lights, alarm, a pa system, maintance, and whatever else that comes along. This golf cart does wheelies and travels thru 7 inches of mud when need be. Two honda eu2000i gens twinned to supply the electrical power. Latest addition an 04 Honda Goldwing. [url]http://www.hometown.aol.com/rvnagain/myhomepage/profile.html[url]
nny12972
NY
Posted: 07/01/08 06:06am Link  |  Quote  |  Print  |  Notify Moderator
If the lights are 12V, I'd say your battery is probably on it's last legs---maybe a case of poor converter, too....and a whole lot of other 12V usage at the same time.....
With a good battery, a couple seconds of 110 voltage drop shouldn't affect your 12V lights at all......I can start my 13.5 A/C off my inverter and my 12V lights don't dim......
J
MNtundraRet
Bloomington, MN
Posted: 07/01/08 06:10am Link  |  Quote  |  Print  |  Notify Moderator
If your RV has a 30 amp cord, and you are using an extension cord, that cord must also be 30 amps. A 15 or 20 amp cord will not allow high enough amperage to power the air-conditioner properly.
Mark
Mark & Jan "Old age & treachery win over youth & enthusiasm"
2003 Fleetwood Jamboree 29
Hornet28BHDS
Parker, PA
Posted: 07/01/08 07:56am Link  |  Quote  |  Print  |  Notify Moderator
It's normal for them to dim for a small time like that, so don't worry about it. Good luck!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
tvman44
Southwest Louisiana
Posted: 07/01/08 03:29pm Link  |  Quote  |  Print  |  Notify Moderator
May have a weak battery.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
