RV.Net Open Roads Forum: Class A Motorhomes: Need opinions on Winnabago Adventure 32'
 > Need opinions on Winnabago Adventure 32'
bcampbell
Lanett, Al USA
Posted: 07/01/08 08:33am Link  |  Quote  |  Print  |  Notify Moderator
I am looking at a 2001 Winnabago Adventure 32' with Workhorse chassis with the 8.1 engine and Allison transmission. What has been your experence with this drive train and with this coach? What fuel mileage?
Coachmen Concord
2004 v10 235SO
Jeep Wrangler-toad
FMCA 164852
Johng
Gilbert, AZ, USA
Posted: 07/01/08 08:36am Link  |  Quote  |  Print  |  Notify Moderator
Had an 04 Adventurer 35' same chassis, the experience was very good. Would check to make sure the plug wires over heat problem had been fixed, it was a recall for 04. Overall very good MH, well made, milage was around 8 towing a toad.
Happy RVing
John and Judy
US Air Force - Retired
05 Beaver Santiam 40DST
08 Malibu Toad/Brake Buddy
Hikerdogs
Wisconsin
Posted: 07/01/08 09:26am Link  |  Quote  |  Print  |  Notify Moderator
Can't help you with the drive train since ours is on the ford chassis. I can tell you it's a good coach. We've had very few problems in 8 years and 65,000 miles. So far the worst problem has been a broken plastic elbow on the inlet side of the water heater. It was a little tough to replace with the heater still in the coach.
Hikerdogs
2001 Winnebago Adventurer
OleRVer
Orlando,Fl.
Posted: 07/01/08 09:49am Link  |  Quote  |  Print  |  Notify Moderator
Good coach, good floorplan....seemed to have a shock issue with this era chassis. Hopefully the original owner negotiated for new Bilstiens!!...as with any used coach, test drive!......good luck.
jchonroad
South Berwick, ME
Posted: 07/01/08 11:28am Link  |  Quote  |  Print  |  Notify Moderator
We have an '05 Voyage with that chassis, that we bought used when it was 2 years old, and had never really been used. (It had 1300 miles on it since delivery.) The only "issues" we've had were the rear axle seals leaked - repaired under warranty. Being somewhat of a mechanic, believe that is was, most likely, due to lack of use. Otherwise, we've had no problems. Gas milage has been between 7 - 8 MPG towing a Cavalier. Doesn't make a difference if we're in the mountains or if the AC is on.
As said previously - test drive ...
Best of luck.
John
John '46
Joyce '46 (DW)
GOOD SAM LIFE MEMBERS
Heidie '00 (13 lb."Guard Dog")
'05 Winnebago Voyage 35A
'03 Cavalier Toad w/Sterling Aluminum Tow Bar & Brake Buddy
Also: '96 Coleman Yukon behind a '03 GMC Sonoma with a Prodigy Controller
dmason
Gaithersburg, MD
Posted: 07/01/08 12:04pm Link  |  Quote  |  Print  |  Notify Moderator
Had a 05 Adventurer, same setup. No major problems. About 8 MPG towing. Wife loved the floorplan and she got 51% of the vote! Enjoy.
Richard & Mary Lou
07 HR Scepter, 42 PLQ
Plus four w/four down:
Casey, Honey, Brady, and Rusty
Birddogman
Pennsylvania
Posted: 07/01/08 01:37pm Link  |  Quote  |  Print  |  Notify Moderator
Can’t help you with the chassis – ours is a Ford, but we have a 2002 32” Adventurer with two slides. We tow a Jeep. So far zero problems other than normal maintenance. We really like the floor plan and the amenities – just right for us – not too much and not too little. We felt that we got a lot of value for the cost.
2008 Winnebago Journey 39z DP
2004 Jeep Liberty toad
