HedoTravelers
Rochester, New York & Jamaica, W.I.
Sorry to hear of your dilemma. I bet you'll never do that again. I use a Hydro Flush to drain & rinse the tanks. That way you can do it all from outside with ease.
Respect,
Brent
TV ~
Cadillac Escalade EXT, Prodigy BC, Reese Pro Series SC
Rigs ~
Starcraft Travelstar 21RBS, Alcan Traveler Tent Camper
"Where ever you go, there you are"
the popes
massachusetts
Well yesterday I took a piece of copper tubing and duct taped a magnet on the end and went fishing in my black tank and came up with nothing. I then filled my black tank with fresh water and flushed, still nothing. I did it a second time and stuck my " fishing pole in the drain and met resistance, loooked in drain with flashlight and there was the can of shaving cream standing up straight in tank right at the drain. I checked tank more closely and found a hose clamp covered with plumbers putty, loosened it and removed pipe and grabbed my catch. replaced pipe with putty and it ended up alot cleaner and easier than I ever thought. And no I wont do that again. Looks like a turbo flush is on my next shopping list at the local Rv dealer. Thanks for all your input.
HedoTravelers
Glad to hear you got it out. Nice job!
tailgater
Cape Cod
You haven't smelled
A face so rank,
Until your can
Falls into the tank.
Burma Shave
Padlin
W. Ma.
tailgater wrote: You haven't smelled
A face so rank,
Until your can
Burma Shave
Thanks, I needed that.
Bob & Deb
W Ma.
04 GMC 1500 4X4, 5.3L
06 Starcraft 18SB
TheGrinch
Western MD
A face so rank,
Until your can
Burma Shave
How appropriate! Great thinking!!
winkyb
the popes wrote: Well yesterday I took a piece of copper tubing and duct taped a magnet on the end and went fishing in my black tank and came up with nothing. I then filled my black tank with fresh water and flushed, still nothing. I did it a second time and stuck my " fishing pole in the drain and met resistance, loooked in drain with flashlight and there was the can of shaving cream standing up straight in tank right at the drain. I checked tank more closely and found a hose clamp covered with plumbers putty, loosened it and removed pipe and grabbed my catch. replaced pipe with putty and it ended up alot cleaner and easier than I ever thought. And no I wont do that again. Looks like a turbo flush is on my next shopping list at the local Rv dealer. Thanks for all your input.
Now you can go back to shaving.
