RV.Net Open Roads Forum: Tech Issues: Dash Radio Performance
 > Dash Radio Performance
novi2some
Novi, Michigan
Posted: 07/01/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
I have a 2006 Daman Challenger with the original in dash radio. The performance is poor especially in the AM mode. There is a lot of static on the AM mode. Also you can here clicking noise on the radio from the wipers again in AM mode. I am also wondering if part of the reason for the poor reception is the antennae installation. The antennae is mounted on the side up front above the drivers window. It lies horizontal just below the roof line. Has anybody replaced this antennae and improved the performance? Or do I need to just get rid of this original radio?
2006 Damon Challenger 355 pulling a 2008 Mariner
trnfla
Tampa
Posted: 07/01/08 07:33pm Link  |  Quote  |  Print  |  Notify Moderator
sounds like an antenna issue to me.
Have a great time camping,
Terry
Please say a Prayer for my 12 month old Granddaughter VisitBella.com
Please visit my Photos and Blog NiceCamps.com
Now 2004 Winnie 31C
Had
2007 Zeppelin EZ190, 2007 Expy
1999 30' Dutchman Classic 5th wheel, 2005 F250
Gdetrailer
PA
Posted: 07/01/08 08:04pm Link  |  Quote  |  Print  |  Notify Moderator
people actually try to use AM radios while travelling???
Basically there isn't much that can be done to clear up the noise except if you turn off the engine and wipers.
While you can toss parts at it, AM just by its very nature is going to pick up noise from engine (ignition), DC brush motors (wipers, fan, starter). Only VERY strong CLOSE stations may have enough signal to over come the noise.
Even replacing with a high quality aftermarket radio may not help, many manufacturers only include AM as an after thought.
Kendas
Tucson AZ
Posted: 07/01/08 10:02pm Link  |  Quote  |  Print  |  Notify Moderator
Funny, I've been doing just that "listening to AM" on the road for 35 years with very few problems with "internal" noise on OEM stock radios. Normally while traveling at night (how I travel mostly) I listen to AM 1040 KNX news radio out of Los Angeles as this is still a 50,000 watt "Clear Channel" station. I can normally pick it up between the north and south boarders of the States anywhere west of St Louis. Yes, it does fade and is little "fuzzy" at times but, I've never had a static "problem" with the OEM radio that wasn't a bad connection in the power/ground or antenna circuits on the vehicle.
Ken
* This post was edited 07/01/08 10:16pm by Kendas *
1978 21ft Tioga Dodge 440 Motor,
4.5kw Generac and 80 watts Solar
Misc Things I've done to my RV pictures
USAF Retired
To Err is human... To Forgive is not SAC Policy.
RJsfishin
Winston Or.
Posted: 07/01/08 10:25pm Link  |  Quote  |  Print  |  Notify Moderator
I have absolutely no am noise on my OEM installed radio.
All my OEM installed radios have been am noise free.
But every time I have replaced an OEM radio, for some reason
the am side has been a static noisy disaster. And no amount
of filtering has ever corrected it either. So I don't replace
radios unless they quit playing.
Rich
'98 Flair, 454, Onan Microlite 4k, Intel PD 9155 w/ wizard, Sta-power 1500 watt Inv, 2 6v batts, ammeters, KingDome/sat, Oly Catalytic Heat, hauling 2 Bent Bikes and sometimes towing a Tracker F&S boat.
novi2some
Novi, Michigan
Posted: 07/02/08 06:35am Link  |  Quote  |  Print  |  Notify Moderator
Thanks for all the info. I will just make sure all connections (ground, antenna) are all in good working condition.
