I purchased a 96 Alpenlite 34RL last year and never used the onboard water for anything because all the camping we did was full hookups, my question is: where is the hose or drain for this tank so I can clean and drain the tank? I looked everywhere on the bottom but no 100% sure I know what I am looking for.
What the ratio of bleach & water to sanitize the tank? it is a 100 gallon tank
Your best bet is to locate the fresh water tank. From there do some searching. If you can see the tank from inside the TT (under dinette or couch, or through a storage compartment) than look around that. if you can not see the tank (concealed under the TT) Than look from a spout hanging under the TT, usually near where you would fill it. It should be located in one of those areas.
Ia gree find the tank and you should be able to find the drain. It may look like the shut off valve on a cooler, just turn the lever and the water drains out. If you never used it there may not be any water in it.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!! MY TRUCK OUR TRAILER
luck would have it wrote: Your best bet is to locate the fresh water tank. From there do some searching. If you can see the tank from inside the TT (under dinette or couch, or through a storage compartment) than look around that. if you can not see the tank (concealed under the TT) Than look from a spout hanging under the TT, usually near where you would fill it. It should be located in one of those areas.
That's great advice for you to follow!
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
ceeyahd1 wrote: I purchased a 96 Alpenlite 34RL last year and never used the onboard water for anything because all the camping we did was full hookups, my question is: where is the hose or drain for this tank so I can clean and drain the tank? I looked everywhere on the bottom but no 100% sure I know what I am looking for.
Look for a red handle between the wheels on the door side of the trailer. That's where the fresh drain was on another 96 I recently saw.
