mxrider101
longview, wa.
hello, i have a atwood model g6a6 water heater in my motor home. lit the pilot today and the burner came on as it should. after a couple minutes it went out and blew out the pilot too. relit, and same thing. now it wont light at all. could it be the gas control valve or what should i try? the pilot did light again but went out before i turned the burner on even. thank you.
buck513
pa
same thing with mine two years ago. i change the thermal coupler first. turn out to be the gas control valve.
buck
2002 Prowler 28x TT
2001 CTD Dodge 3500 QC Dually
2003 CTD Dodge 2500 4 door SB
Dick A
Spokane Valley
Moved from General RV'ing forum.
Check out the RV.Net Blogs at: blog.rv.net
mikey98e
Natick, MA, USA
Same thing with mine I changed the thermocouple and pilot light. It works fine now.
-mike
Rose & Mike
2006 GMC 3500 SRW 4x4 8.1/Allison - 1996 21' Mallard
Courtney (the Sheltie) & Chet (the Setter)
mxrider101
longview, wa.
okay, so should i go with the thermal coupler firts? the control valve was about $75, whats a thermal coupler cost and where do i get the best deal? thanks
MELM
GA
Link to Atwood Operating Manual.
On page 5 are some instructions for cleaning of the burner, etc. You may have spider webs in the burner tube since the burner went out and blew the pilot out.
You can also disconnect the thermocouple from the main valve and clean the connection - it is an electrical contact - and reconnect it. That sometimes is the problem.
The pilot should stay lit as long as you hold the reset - it bypasses the thermocouple input to the main gas valve to allow the pilot to be lit.
On some models, a "general purpose" thermocouple available at hardware stores, etc. will fit. Others, you may need to go to an RV dealer or an online RV seller to get the correct one.
Mel & Mary Ann; Mo'Be (More Behave...) and Bella
"If you have an RV, you don't need another hobby." Comment from a friend...
73 Kountry Aire 31.5 ft (semi-retired) TT
90 Champion LaSalle MH 29 ft P30 (89 Chassis)
Visit The Official Blog of the Open Road
mxrider101
longview, wa.
it doesnt have a button to hold, just turn the knob to pilot, wait a min., and turn the knob to on. also, on the gas valve is a sticker that says "equiped with a single use shut off valve. if circuit is open, replace valve." how do i know if the circuit is open? i will try these suggestions and hope for the best. thanks
mxrider101
longview, wa.
i got it fixed. turns out that the pilot orface was a little plugged. took it apart and blew it out and she works top notch now!! thanks to everyone for your input and help. just in time because we go on our trip in the AM. again, thank you!!
