RV.Net Open Roads Forum: Fifth-Wheels: fresh water holding tank
 > fresh water holding tank
houhjc
at the pump, tx
Posted: 07/02/08 05:40am Link  |  Quote  |  Print  |  Notify Moderator
how do i get to my fresh h2o tank under my cedar creek? its a 362bbs, and it has the enclosed bottom, all i can see is a drain hose hanging out. I would think it would be able to be inspected from inside somewhere? probably not, my luck, ill have to take half the trailer apart. thanks for the help.
2007 Ram 3500 6.7 DRW 4X4 6speed manual
2003 362bbs bunk house
outdoorsman2007
In the Woods - Somewhere!
Posted: 07/02/08 06:19am Link  |  Quote  |  Print  |  Notify Moderator
Can I ask why you need to get to the tank?
webeopelas
VA
Posted: 07/02/08 06:59am Link  |  Quote  |  Print  |  Notify Moderator
You will have to drop the underbelly. No way around it. More of a hassle than hard.
houhjc
at the pump, tx
Posted: 07/02/08 08:56am Link  |  Quote  |  Print  |  Notify Moderator
a month ago, i took a trip and left at night. my holding tank was full, because we were boondocking. while going down the freeway, i noticed water hitting the road behind me when a car would be close. when i got to where i was going, my tank was almost empty.
last week, we took a trip and i normally put about half a tank of water for the road. my brother was behind me and told me water was steadly dripping from the overflow hose. enough to be concerned about. i am boondocking again next weekend, and would like to see what the problem is.
riddellr
Belleville, IL, USA
Posted: 07/02/08 09:04am Link  |  Quote  |  Print  |  Notify Moderator
Try capping the overflow hose while traveling. I have a Jayco Qwest 265 and once water starts flowing out of the tank vents, they act as a siphon and drain the tank considerably while traveling. This may be happening to you. I recently tested the siphon theory by filling the tank until the vents overflowed, then blew air back up through the two vent lines. Once the water stopped flowing the siphon was broken and nothing more leaked out, until I went around a corner and started the siphon again. I plan to put valves on the two problem vent lines and close them when traveling. Good Luck.
Bob
houhjc
at the pump, tx
Posted: 07/02/08 09:15am Link  |  Quote  |  Print  |  Notify Moderator
in order for a syphon to happen, wouldnt the vent hose have to go into the tank? i would think that it would just be slid on a nipple with a hose clamp, not extending down into the tank. but i dont really know. im learning more everyday, exactly what i dont know!!!
dhamblet
Olympia, WA
Posted: 07/02/08 08:22pm Link  |  Quote  |  Print  |  Notify Moderator
You start at the front and remove the belly covers as far as you need for what you are doing. I had to also pull the spare tire holder and propane line which crosses up front plus I had to cut off the ABS drain fittings and reglue them with abs sleeves later. Might be a good time to check everything out or install some tank heater pads.
2005 Dutchmen 35SRV, Pergo floor, 5th Airborne, JT Strong Arm, Kodiak Disk Brakes, Backup camera
2006 Dodge CTD RAM QC 3500 LWB 4WD, Reese 16k, Airlift, Pacbrake, Britebox, 60g aux fuel tank
04 HD Ultra, CanAM 400MAX Quad
Spending my kids inheritance
houhjc
at the pump, tx
Posted: 07/03/08 05:58am Link  |  Quote  |  Print  |  Notify Moderator
dhamblet
Olympia, WA
Posted: 07/04/08 11:35pm Link  |  Quote  |  Print  |  Notify Moderator
It helps to have pneumatic tools. With a air rachet you can really get with it on all those screws holding the belly pans on.
04superduty
Michigan
Posted: 07/06/08 08:22am Link  |  Quote  |  Print  |  Notify Moderator
or a cordless drill with the correct socket on works well also.
04 F350 6.0PSD/TS EC SB
07 Outback Sydney edition
