RV.Net Open Roads Forum: Forum Logon from Good Sam Site Problem not RV.net
Search only in Forum Technical Support
Open Roads Forum  >  Forum Technical Support
 > Forum Logon from Good Sam Site Problem not RV.net
Ames
South Central Florida
Posted: 07/02/08 06:50am Link  |  Print  |  Notify Moderator
I get this message from the hyperlink from the Good Sam web site when trying to access forums but the RV.Net link works OK?
(Copy)
Error Occurred While Processing Request
File not found: /cforum/index.cfm
Please try the following:
Enable Robust Exception Information to provide greater detail about the source of errors. In the Administrator, click Debugging & Logging > Debugging Settings, and select the Robust Exception Information option.
Check the ColdFusion documentation to verify that you are using the correct syntax.
Search the Knowledge Base to find a solution to your problem.
Browser Mozilla/4.0 (compatible; MSIE 7.0; Windows NT 5.1; Q312461; iebar; .NET CLR 1.0.3705; .NET CLR 1.1.4322; .NET CLR 2.0.50727; .NET CLR 3.0.04506.30)
Remote Address 74.4.97.48
Referrer http://www.goodsamclub.com/forums/default.aspx
Date/Time 02-Jul-08 06:45 AM
"end of copy"
Is it me or their site?
Richard and Babs and a Bob Tail Cat
97 Beaver Patriot 40 Kitchen Slide
330 HP Member FMCA, BAC, Good Sam, CAT RV Club
Toad 04 Durango HEMI
pulsar
Lewisville, NC
Posted: 07/02/08 07:15am Link  |  Print  |  Notify Moderator
It is not you.
We will defer this thread to an already active thread about the topic.
If you want to comment on this topic or see what others have said you can do so here.
Good Sam Club
Closed
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
