snarfattack
Chicago, IL
Do NOT simply replace the 20 amp fuse with a 50 amp fuse! 20 Amps is most likely the max amperage based on the length of the wire. This site has a car audio section down the page that will give you a safe wire gauge based on length and amperage.
http://www.epanorama.net/documents/wiring/wire_resistance.html
1999 Jayco Eagle 304BH
2003 Chevy Suburban 1500
keljohnso
North Carolina
No, no, no, I wouldn't do that. Actually, I'm looking to replace the wire with some #4 and about 150 amp fuse or circuit breaker. I found the manual for the inverter and got some info. Thanks!
2oldman
WA
keljohnso wrote: I found the manual for the inverter lol
Rick From Sequim
Sequim, WA
Like AlanB says, or to repeat Watts = amp times volts. Therefore, 600 watts at 120 volts, draws 5 amps. An inverter drawing 12 volts to deliver 600 watts = 600 / 12 = 50 amps.
Ain't no free lunch. A watt is a watt is a watt, regardless of the voltage.
Rick
& wife Loie & Kodi Dog (blk male std poodle)
1995 F-250 460 Banks (wow!) & 2005 25' Bigfoot RQ
The_Vintagers
Georgia USA
anything that heats or cools pulls more power. I suggest a coffee maker to put on the stovetop.
javaseuf
Southern Cal
The_Vintagers wrote: anything that heats or cools pulls more power. I suggest a coffee maker to put on the stovetop.
Except a swamp-cooler.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
keljohnso
North Carolina
We tried that, it takes too long. I'd rather use battery that can be recharged, than 45min. worth of LP.
javaseuf
Southern Cal
keljohnso wrote: The_Vintagers wrote: anything that heats or cools pulls more power. I suggest a coffee maker to put on the stovetop.
45 minutes worth of propane? It takes my 2 quart tea kettle about 12 minutes to reach boiling and I have enough hot water for 10 cups of coffee. And I do believe the propane will be cheaper that gas for a gennerator to run the coffee maker or charge your batteries after the invertor draws them down.
Ans since a genny will be needed to recharge the batteries, unless you have solar, why not just run the genny to power your coffee maker?
