RV.Net Open Roads Forum: Fifth-Wheels: Did I wreck my axles??
 > Did I wreck my axles??
Polishnurse
Schodack, NY
Posted: 07/02/08 06:24pm Link  |  Quote  |  Print  |  Notify Moderator
Guess we all have different ways of doing things, I see a jack overcoming the the height of axial, the height to springs, then the additional height of the compression of spring, then to exceed the height of the compression on the tire. will almost surely be quite a balancing act. Plus you most likely be throwing all the weight to the trailer to the opposite side adding additional weight to the two remaining tires on the ground. After you get it up there so your tires are clear, the none gusseted rail you have the jack on decides going to fold under the weight of the combined load. Nope not for me, I'll just roll the trailer up on to a piece of two 2X6" just giving the other wheel enough clearance to remove it. Keep the weight of the trailer on the other three wheels which should be above there rated load range. But you do it as you see fit. Good Luck and happy tire changing. Bill
JIMNLIN
Big Cabin, OK
Posted: 07/02/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
trekker
there is certainly nothing wrong with jacking the axle on a standard suspension trailer. I wouldn't go much farther than a 6-8 inches inside the axle U bolt especially on heavier trailers. I've jack from 2750 lb axles to 8000 lb axles with no problems. Fact I never heard of not jacking from the axle or have I ever heard of axle problems from jacking the axle until I became a RV.net member.
Jim
'03 2500 Dodge/Cummins HO 3.73 6 speed manual Jacobs
'97 Park Avanue 28' with two slides
Rossey
Appomattox, Virginia. / Rockville, Maryland
Posted: 07/02/08 07:28pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
trekker
Jim
X2
83trekker
calgary,ab,canada
Posted: 07/02/08 08:02pm Link  |  Quote  |  Print  |  Notify Moderator
JIMNLIN wrote:
trekker
Jim
Me too never heard of untill this site, then it saids it in my prodigy install manual, and on the dexter axle website and now see it every where i read.So i did build a 2x6 boards to drive up on and just be as quick as possible. Thanks guys
yardsale1
Orange County, California
Posted: 07/02/08 08:26pm Link  |  Quote  |  Print  |  Notify Moderator
ShapeShifter wrote:
skipnchar wrote:
Time will tell if you did any damage but I'd never jack up my trailer at all. Just not worth the risk in my opinion.
Then how do you change tires, service brakes, or repack bearings?
I guess you don't.
2007 Keystone Raptor 299MP
wintek
Shreveport, Louisiana
Posted: 07/02/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
The Dexter manual says to use the frame.
Glen41
North Texas
Posted: 07/02/08 09:06pm Link  |  Quote  |  Print  |  Notify Moderator
Of course Dexter says use the frame. They don't even like you to touch thier axles. If they could, they would force you to bring them in for bearing repacking. That's like asking a barber if you need a haircut
Cox89XJ
Tennessee
Posted: 07/03/08 12:46am Link  |  Quote  |  Print  |  Notify Moderator
My springs are above the axle. I know it may be a dangerious, but I use the spring U bolt to jack the axle up. I've thought about making an adapter for the bottle jack that will cradle the U bolt.
JIMNLIN
Big Cabin, OK
Posted: 07/03/08 05:44am Link  |  Quote  |  Print  |  Notify Moderator
Cox89XJ wrote:
My springs are above the axle. I know it may be a dangerous, but I use the spring U bolt to jack the axle up. I've thought about making an adapter for the bottle jack that will cradle the U bolt.
another good cradle is a short piece of channel welded to the jack. Works great for cradling different size axle tube's.
Jim
smurf
South Dakato And Wa.
Posted: 07/03/08 08:16pm Link  |  Quote  |  Print  |  Notify Moderator
After over 20 years as a shop Foreman and changing hundreds of bent axles ,YOU NEVER JACK ON THE AXLE TUBE !!!!!!ALWAYS ON THE FRAME !!!!The camber is set at the factory . I have never seen a bent spindle . The axlesmost often bend outside of the spring hangers . Most often from hitting a curb or pot holes at high speed .  Remember all axle tubes are the same the spindle and bearing sizes determine the axle rating and some are just a different composite of the brake shoes .
2004 GMC HD 4x4 Douramax with Allison transmission loaded.
20005 36ft. Everest W/ 4 slides loaded.
Full timing and having fun
No matter where you go there you are
Papa Smurf driver
Mama Smurf Professional Passenger
