RV.Net Open Roads Forum: Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
 > Dexter HD Suspension & EZ-Flex Install (long w/ pictures)
Page of 34
Dixonmatco
Santa Rosa, California
Posted: 07/03/08 10:01am Link  |  Quote  |  Print  |  Notify Moderator
Les, Where did you purchase this kit and what was the price?
2000 Chevy Silverado 1500
2005 Komfort Trailblazer T23S
Honda EU2000I
sweethome alabama
Scottsboro, Alabama
Posted: 07/03/08 02:23pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks Les for the pics. I stumbled across EZ Flex about a week ago and started trying to do a little research on them. May try to install in the future on mine, Did it improve the ride on your old trailer? Could you tell alot of difference in the tow vehicle? Is there a way to save articles like this in your profile for easy access for future use? Thanks Mike
04 suburban 1500
00 silverado 1500
05 jayco 27bh
Couldn't get rig to post,so here is my burgler alarm!!
our pics
BarneyS
S.E. Lower Michigan
Posted: 07/03/08 02:40pm Link  |  Quote  |  Print  |  Notify Moderator
Don't know where Les got his from but I purchased mine from Eastern Marine. They had the best price by far and I got the package today after only four days. Price was $159.95 plus $12 shipping. (Edit 9/15/08: I see the price has gone up and is now $241.95)
The price from Dexter Axle was $239.46 plus shipping.
Be aware that if you Google the kit, some places advertise a similar price but it is not for the complete kit. (Example) It is just for the unit and the two main mounting bolts and does not include the wet bolts for the links and other parts. Be aware of what you are ordering!
Barney
* This post was last edited 09/15/08 06:41pm by BarneyS *   View edit history
Hensley "Arrow" 1400# hitch
2002 Ford F250 Super Duty, 7.3L PSD
Visit our website here
sure2rain
Sunbury, PA
Posted: 07/03/08 06:39pm Link  |  Quote  |  Print  |  Notify Moderator
Great post, Les. I've been thinking about changing mine but wasn't sure exactly what all was involved. Your post and pictures will be very helpful if/when I decide to go ahead with the change.
TV: 05 Chevy 2500 8.1L
5er: 2010 Open Range 385RLS
Hensley Arrow and P3
coolbreeze01
Redding, Ca
Posted: 07/03/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
Very nice. Does this come stock on any TT's?
2008 Dodge 3500 With a Really Strong Tractor Motor...........
LB, SRW, 4X4, 6-Speed Auto, 3.73, Prodigy P3, Blue Ox Sway Pro........
2007 Komfort 212 on 225 75R 15E Maxxis 8008 Tires.........
Dixonmatco
Posted: 07/03/08 07:20pm Link  |  Quote  |  Print  |  Notify Moderator
Yes, Komfort is putting it on their trailers starting with the 2008 year models.
LAdams
Northern Illinois
Posted: 07/03/08 11:08pm Link  |  Quote  |  Print  |  Notify Moderator
I got mine directly from Dexter but Barney got a much better price - wish I would have saw that before I ordered... Actually that kind of surprises me because I order all my bearings and seals from Dexter and they beat the local auto suppliers by huge margins - Oh well ...
But I did order in kind of a hurry as I had a ton of stuff going on in my life then with work and retirement just around the corner (I did retire June 30th) ... But then I figured I saved a TON of money doing it myself... Even if my dealer could have installed it in say 6 hours (which I doubt) at his labor rate that would have been almost $700 in labor!!! And working on my TT is my therapy - I love to do it...
Haven't towed with it yet - we'll be going out July 16th so I'll be able to report after we get back after that weekend... It amazes me that Dexter only installs those cheap little nylon bushings on their OEM axles rather than using bronze bearings and wet bolts... Perhaps that's a Skyline spec when they order axles from Dexter - I dunno
I will say that it is a challenging job, at least for these old bones ... I'm not as agile as I used to be and think I have a touch of arthritis and crawling around on the paver driveway for 2 days got me pretty sore... It would have been a lot easier with a buddy too - trying to start a bolt when tugging on a breaker bar trying to move an axle into place was just about all I had - could have used an extra set of hands on more than one occasion...
But still, it was a fun job and it only took 2 days, so I just figure all those dollars I saved and the pains go away - you can buy a lot of Tylenol for $700 bucks
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
Sold Trailer - not RV'ing at this point in time
HUNTER THERMOSTAT INSTALL
HOME MADE WHEEL CHOCKS
JIH
Roseville, CA
Posted: 07/03/08 11:41pm Link  |  Quote  |  Print  |  Notify Moderator
LAdams wrote:
Each greasable bolt has 1 hole in it... According to Dexter, the hole exit is supposed to be in a horizontal plane rather than a verticle plane... I haven't sat down ad figured out what forces are in play in the axles, bolts, hangers, etc but I guess that this is the ideal position for the greasable bolt to be in so that grease will flow readily thru it and lubricate the balance of the bolt surface...
The reason is that the max wear areas are at the top and bottom. Where there is wear, there is metal movement in brass bushings. The movement can cause the hole to slowly fill with this moved metal. It has to go somewhere.
2000 Southwind 36Z
2004 GMC Canyon, Toad
pete42
Ohio
Posted: 07/04/08 07:36am Link  |  Quote  |  Print  |  Notify Moderator
Very nice job and this post should go as a reference for any of us planning on this Mod.
Again very nice job.
PETE
LAdams
Northern Illinois
Posted: 07/04/08 11:14pm Link  |  Quote  |  Print  |  Notify Moderator
I'll ask Admin to make it a Sticky at the top of the TT Forum - look for it there in a day or so...
Les
Page of 34
