RV.Net Open Roads Forum: Towing: SEVERE sway with my 2008 cougar304BHS?????
Search only in Towing
Open Roads Forum  >  Towing
 > SEVERE sway with my 2008 cougar304BHS?????
Page of 5
LAdams
Northern Illinois
Posted: 07/06/08 07:43pm Link  |  Quote  |  Print  |  Notify Moderator
There's a lot of "shootin from the hip" going on here but Crappie_Fishermna is calling it correctly... The "sticky" in question is a very through adjustment procedure of a w/d hitch... Until this is done, you judt don't know where your at... Once you get the hitch adjusted properly, haul the rig over to the scales and see what your weights are - make sure your within GVWR and GCWR of your truck... Is your truck suspension up to specs??? - ball joints and tires all OK??? There are a ton of things that can cause sway from one truck to antother - you must start at the beginning in a methodical and orderly elimination of possible causes one step at a time... Hitch adjustment is your first step - report back after you have siccessfully completed the PROPER hitch adjustment...
Les
2000 Ford F-250SD, XLT, 4X4 Off Road, SuperCab
w/ 6.8L (415 C.I.) V-10/3:73LS/4R100
Banks Power Pack w/Trans Command & OttoMind
2006 Nomad 3150 Double Slide (Bunkhouse)
Hensley Arrow
Jordan Ultima 2020
HUNTER THERMOSTAT INSTALL
** NEW ** blog.rv.net
scottcougar
Saskatchewan
Posted: 07/07/08 09:46pm Link  |  Quote  |  Print  |  Notify Moderator
where exactly is the fresh water tank located on my 2008 cougar 304bhs? I have POLAR package and cant see anything. Would it be back half of trailer or front half?
LeeShearer
Royersford, PA
Posted: 07/07/08 10:03pm Link  |  Quote  |  Print  |  Notify Moderator
The tank should be right below the tank fill.
2005 Fleetwood Resort EXT 25SB
1999 Chevy K3500 short bed dually
Airstreamer67
Pineville, LA USA
Posted: 07/08/08 02:15am Link  |  Quote  |  Print  |  Notify Moderator
Water weighs a lot and can make quite a difference in some rigs. Have you tried towing with and without water with the truck that demonstrates the sway?
scottcougar
Saskatchewan
Posted: 07/08/08 05:25am Link  |  Quote  |  Print  |  Notify Moderator
my drain is almost athe front of the tt. everytime my FIL truck pulled my TT the tanks were empty
scottcougar
Saskatchewan
Posted: 07/08/08 06:02pm Link  |  Quote  |  Print  |  Notify Moderator
go figure. ill just pack tons of beer/stuff in the back portion of my cougar 304 bhs. And fill up fresh water tanks. maybe im a lil too much tongue weight? can too much tongue weight cause sway?
LAdams
Northern Illinois
Posted: 07/08/08 10:22pm Link  |  Quote  |  Print  |  Notify Moderator
Scott - with all do respect, all this bantering back and forth doesn't mean much or solve your problem unless you weigh the rig and find out EXACTLY where your at in terms of overall weight, tongue weight, hitch adjustment, etc...
Ans yes - taken to an extreme, too much tongue weight can also cause sway and towing instability...
Give us some weights and verify your hitch adjustment otherwise all the questions and possibilities are meaningless...
Les
Rich K
YAMHILL OREGON
Posted: 07/08/08 11:11pm Link  |  Quote  |  Print  |  Notify Moderator
I myself have been were you are long story short new 2008 cougar 300srx 35 footer used my old tow hitch from old truck dealer said it will work fine....
right...... my 2005 dodge 2500 4door shortbed cummins sat taller so the rear of the trailer was sittin low did a little 50 mile short camping trip scared the******out of me .... trailer was all over the place truck felt like it was loose in the rear and corners was even worse ........
i could see the rear of the trailer swaying side to side. I was so glad to get there and all i could think of was the ride back home. I moved things inside the trailer and played with the weight bars sway and nothing worked...
So i tossed the hitch and got a 8 inch drop from the dealer that told me the other one would work and let them know i was pissed off about the bad info and how they could even say that would work. I did put air bags on to stay off the over loads and get a nice ride and a new set of shocks.... I just did a 600 mile trip over the hills and corners 60 to 65 highway and wow no sway trailer pulls like a dream not scared ..... and the drive was so nice I made sure the trailer was level loaded it lifted the bags so there was a slight dip on the hitch and bam..................love it. GOOD LUCK
advntrs
greenwood, Indiana
Posted: 07/09/08 07:05am Link  |  Quote  |  Print  |  Notify Moderator
It sure makes sense to me, that whenever you change tow vehicles, it would be important to recheck all of the weight distribution factors.
One thing I feel very strongly about. These anti-sway friction bars lead folks into a false sense of security when used on trailer over 23'. I think these types of anti-sway bars should be limited to a length of 20' or less. I have actually seen cases where these bars were literally destroyed or torn from the frame of the trailer by severe sway.
These devices would never be approved for commercial use and in my mind are very dangerous and lead to many accidents when used on longer TTs.
I think what is going to happen here is that the dealers, in their haste to sell "anything" and get you off the lot as quickly as possible, are going to lead to federal laws about what you tow and how you tow it.
"Behind each great fortune,lies a great crime"
Keith99RS
Suffield, CT
Posted: 07/09/08 08:37am Link  |  Quote  |  Print  |  Notify Moderator
What is your WD Hitch rated for? What style is your Ram vs FIL's Ford? (i.e. crewcab, supercab, bed length.....)
Smoke 05 Titan SE CC 4X4
K&N panel filter
PRG 2.5" Leveling kit
Bilstein front,Icon rear shocks
Powerstop slotted rotors
18" Wrangler AT/S LT's
2009 Fleetwood Prowler 2702BS
Primus Brake Controller
Reese DC w/ 1,000lb/10,000lb WD
Page of 5
