billandjan
Jacksonville, FL
Has anyone tried towing the new Astra from Saturn? The 2008 Guide to Dinghy Towing by Motorhome magazine has an article that states that the Astra is flat towable. However, the owners manual and Saturn say that the Astra is not "designed or intended to be towed because of low ground clearance". We are confused and wonder if anyone has yet successfully towed a Saturn Astra.
Bill McClure
janice.mcclure@comcast.net
great dane
borrego springs ca.usa
Recently we purchased a 08 Saturn VUE XR as our new towcar, before we closed the deal I called the Saturn factory and asked about flat towing, they stated "all 08 Saturn models are flat towable". By the way we are very pleased with the VUE
GD
Not a Clue
Southern Ca
We went to check out the Astra when first became available. We were told the the manual transmission was towable but not the automatic, because it was imported and had a different drive train. We, also, decided on the Vue and are very satisifed with our decision.
Linda B.
2006 31' Fleetwood, TiogaSL - The Big Bus
2008 Saturn Vue (Toad)with US Gear UBS
& Demco baseplate and tow bar.
Traveling with Robin(friend),Liz(cockapoo)&Buddee(cavalier)
pulsar
Lewisville, NC
Moved from Forum Technical Support.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
etrippe
Ann Arbor, MI
Hi, we too are looking at the ASTRA and are confused on its towability. Did you buy the Astra, and are you towing it? Any final deciesion on being able to be flat towed?
golfknut
SW Michigan
I checked the owners manual of an Astra at an auto show last weekend.
It said the Astra is NOT flat towable....at least the automatic model I was looking at.
I've read earlier, and the salesman confirmed, that the Astra is a Belgian design. I wasn't totally sure if it meant that it is built in Belgium and imported or it is built in America but is a belgian design.
edited 09/13/08 06:38pm by golfknut *
2005 Jayco Granite Ridge 3100SS
RLS2
Eureka, MO
I have been told by the Factory that the 2008 Saturn VUE REDLINE can not be towed behind a motorhome.
RLS2
