RV.Net Open Roads Forum: Class C Motorhomes: Oil Changes
 > Oil Changes
bcgarrison
Goodrich, Mi 48438
Posted: 07/04/08 08:48pm Link  |  Quote  |  Print  |  Notify Moderator
What are the best facilities to obtain oil changes while on the road?
24' Class C
Thanks
ronfisherman
SE Michigan
Posted: 07/05/08 02:17am Link  |  Quote  |  Print  |  Notify Moderator
I like to use Speedco. A 24' should be able to use any oil change place. Including a Ford dealer.
Saf-TTE tire monitor
Polishnurse
Schodack, NY
Posted: 07/05/08 06:05am Link  |  Quote  |  Print  |  Notify Moderator
You can any facility that has a door large enough to let you in, Jiffy Lube, Walmarts, Instant Lube just to name a few. Bill
buchrob
Stanstead QC
Posted: 07/06/08 09:01pm Link  |  Quote  |  Print  |  Notify Moderator
Any service center with a pit will be fine. The limiting factor is how high the ceiling is in the garage if they have to put it on a lift.
'99 Glendale Royal Expedition 24' Class C
2003 Subaru WRX wagon as toad.
trashman66
Nocatee, Fl
Posted: 07/07/08 05:34pm Link  |  Quote  |  Print  |  Notify Moderator
I went to a speedco one time and they said they would have to go to the parts house to get the filter because they didnt stock it. So I would at least carry some oil and filter in case.
kendall69
Palm Springs California
Posted: 07/08/08 04:22pm Link  |  Quote  |  Print  |  Notify Moderator
None there all bad.
2002 - Bigfoot M-29G, 2004 Jeep Rubicon Toad
Dakzuki
Carnation, Wa, USA
Posted: 07/11/08 09:40pm Link  |  Quote  |  Print  |  Notify Moderator
24' Class C
Thanks
Not some place with a zit face kid tring to push fan belts, radiator fluid, and tire air on you.
That would be places that have Speedy, Jiffy and the like in their name.
I used to work at an independant shop and saw the results of their work.
95 Chinook Premier
Arborist
Tacoma
Posted: 07/12/08 08:09am Link  |  Quote  |  Print  |  Notify Moderator
I buy one of the $8 plastic oil drain units, MotorCraft oil filter and oil at Walmart, then change the oil myself.
I leave the old oil at a recycle center. When I'm back home I use a Ford truck center to do the job.($50.00) I also asked for and got some of the oil change stickers from Ford, helps me keep track, and satisfies the folks at Ford that the warranty oil change was done by them.
Maybe not 100% honest, but real hard to find a oil change place that doesn't want to charge an arm or leg, or can't do the work correctly while on the road
Arborist.
"If hard work were such a wonderful thing, surely the rich would have kept it all to themselves." - Lane Kirkland
 > Oil Changes
