RV.Net Open Roads Forum: Class A Motorhomes: K&N Air filter Oiling
 > K&N Air filter Oiling
ct78barnes
Bryan Ohio USA
Posted: 07/05/08 06:43am Link  |  Quote  |  Print  |  Notify Moderator
Getting ready for our two week vacation next week and after changing the oil and filter in my F53 was ready to recharge my air filter and I cleaned it at am letting it dry overnight. I have read on these forms that you can over do it and get to much oil on these filters and mess up a air censor or something. My question is how do you know when you have enough oil on it. I have the oil in a bottle and it states to run down each crevice till pink Any one who has done this and survived the process I would like to hear from you . Last if the air censor light would go on is it going to hurt to keep driving it till I get to my campground or not. Thanks
CSpenceFLY
Macon,Ga
Posted: 07/05/08 07:20am Link  |  Quote  |  Print  |  Notify Moderator
I think you would have to really over do it to damage the air censor.
Just spray a good coat on the filter. After sitting for a few minutes any areas that don't have enough will look light. If you happen to get too much on any areas you can alwaysm blot it with a paper towel.
"You're lucky to be alive my friend."
Quote from the "Do it yourself police" and many others that have known me.
gillguy
Valdosta, GA
Posted: 07/05/08 07:34am Link  |  Quote  |  Print  |  Notify Moderator
The color should be very uniform across the filter. Depending on which size filter there are supposed to be so many ounces of oil used on the filter, if you exceed or don't get the filter covered with the set amount, start over.
Yes it can mess up your MAF (Mass Air Flow) sensor, and yes it does affect your air/fuel mixture. It want destroy your engine, but your performance/MPG will terrible, if it will run, sometimes the engine will stall fram a bad MAF sensor. The sensor can be replaced, they cost anywhere from $17.00 to 125.00 depending on vehicle.
Good luck.
Bobby (USAF Retired)
2007 Chevy 2500 LBZ Duramax C/C, S/B 4X4
2006 Rockwood 8317SS
1973 Airstream Ambassador
Old Town Penobscot 16
oemtech
Elgin, Texas
Posted: 07/05/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
I have been using this type of filter for years.
1) Clean the bugs and any other stuff from the filter before you wash it.
2) Spray a liberal amount of cleaner on the filter and let it stand for 15 or 20 mins. Now slosh up and down in a bucket of water. Toss ou the dirty water and replace with clean and repeat until all the cleaner is rinsed out. Let dry overnight.
3) I use the red oil. Spray a coat of oil on the filter and let set overnight. This will allow the oil to "wick" into the gauze. If it is a light pink then add another coat. It should be a bright red not dark red.
If you have a round filter that clamps on to a tube you can use you shop vac to test for over oiling. Just take a piece of cardboard that covers the filter, cut a hole in it for the vac hose and let run for about 10 mins. Now look at the shop vac hose.
The MAF can be cleaned with CRC MAF Cleaner. DO NOT use brake or carb cleaner as it will eat up the plastic and probably ruin the IAT probe and/or sensor wires.
I bought a NEW MAF cleaner off EBAY for $26 for my 8.1l Vortec.
* This post was edited 07/05/08 08:28am by oemtech *
Dale
Visit my Web Site
2004 Mountain Aire 3651
Steer Safe/2 Koni's/2 Bilsteins/UltraTrac Trac Bars
UltraPower/DIY CAI/DIY Ram Air Scoop/OEM Engineering Fuel Filter Adapter
97 Honda CR-V Toad, Roadmaster 5K Tow Bar,US Gear Unified Tow Brake
Dale's Photo Pages
427435
Rochester, Mn
Posted: 07/05/08 12:01pm Link  |  Quote  |  Print  |  Notify Moderator
I skip all of the above and just buy a new OEM filter. Not only is it easier, but I have better filtration and longer engine life.
Air Filter Test
Mark
2000 Itasca Suncruiser 35U on a Ford chassis
2003 Ford Explorer toad with US Gear brakes,
ReadyBrute tow bar, and Demco base plate.
Jerry B
Ozark Highlands
Posted: 07/05/08 12:22pm Link  |  Quote  |  Print  |  Notify Moderator
Air Filter Test
I wonder what the advantage is going to the K&N, Seems like a lot of trouble and turning back time. I remember having to clean and reoil the vintage oil bath air cleaners. What a messy job!
Jerry B
1996 Dolphin 535,F-53.
Movie Man
Tennessee
Posted: 07/05/08 01:28pm Link  |  Quote  |  Print  |  Notify Moderator
Air Filter Test
This test looks like a plug for AC Delco and the GM Duramax. lol
Scott and Kim
2001 Tiffin Allegro Bay 36DB V-10 w/2 slides
20ft. Enclosed trailer toad with 2 racing Quads (ATVs) inside Honda TRX450R and Yamaha YFZ450 5004x4 Arctic Cat (Wife's)
SpinRite
Research Triangle, NC
Posted: 07/05/08 01:50pm Link  |  Quote  |  Print  |  Notify Moderator
My son gave me a birthday gift of a K&N filter for my toad last year. I felt about the same way that 'Jerry B' does, but installed it anyway.
Air Filter Test
After reading this test data, I see that our suspicions are confirmed.
(Now, if we could just get this kind of real data on those Air-Tabs....
'94 Holiday Rambler Navigator
38', Cummins 8.3 300hp, Allison 3060
pushed by a 2005 Honda Element
Wherever I happen to park
Posted: 07/05/08 02:03pm Link  |  Quote  |  Print  |  Notify Moderator
There is a belief that the K&N filters can pass more air than a standard paper filter... (At least that is what they say) with little, if any, reduction in filter performance. Others say the reduction in filter performance is great and that the problem the OP mentioned is common
I've spoken with a lot of folks who use K&N under some rather nasty conditions, have done so myself, no I mean ZERO evidence that the filter is not doing it's job 100% The oil catches the dirt just fine
And I have yet to read one message from someone who had sensor problems because of it..
NOTE: This does not mean that these problems don't exist, only that I've not read about them
(Of course the last subject where I made a statement someone promptly completed my education by posting an problem report)
ct78barnes
Bryan Ohio USA
Posted: 07/05/08 02:11pm Link  |  Quote  |  Print  |  Notify Moderator
Thanks for the quick responses I did over do it and had to let it sit on paper and the oil keep coming out . Let it set for a few hrs in till no more red oil came out of bottom. . Mine is like a turbine so it was hard to tell how much oil was going in . It was a bright red and covered well over the whole filter . I think before we go on Thursday I will pull it out and check to see if there is any oil sitting in or around the tube. Thanks again for all your help
