RV.Net Open Roads Forum: Beginning RVing: 30 amp trailer at 50 amp site
 > 30 amp trailer at 50 amp site
ebrv
Massachusetts
Posted: 07/05/08 08:18am Link  |  Quote  |  Print  |  Notify Moderator
Our trailer has a 30 amp service. Is it ok to plug in at a 50 amp site with an adapter?
JFG
TN
Posted: 07/05/08 08:21am Link  |  Quote  |  Print  |  Notify Moderator
Yes
Fred
BlackSilver
East of Heaven, North of Hell
It will work fine with the adaptor. You'll probably find that the 50 amp site also has 30 amp connections making the adaptor unnecessary.
Hans, KØHB & Colleen, KØCKB
Master Chief Radioman, US Navy
'04 Prairie Schooner 34FBR Platinum XL
'08 3500HD Silverado Big Dooley LTZ Go-power by Max & Allie
My rig (Click)
NCHornet1
Mt. Airy, NC.
Posted: 07/05/08 12:15pm Link  |  Quote  |  Print  |  Notify Moderator
I have never seen a 50amp only site, usually they have a 30amp beside the 50.
NCH
2000 Ford F350 4X4 PSD,CC, DRW
4:10's, BTM Muffler, Isspro Gauges,
Coolant Filter,CCV Mod
FTVB , Ford AIS
6.0 Cooler,SCT2 W/DP's 40 tow & 80 econo,Zoodad mod
2005 Keystone Hornet 30BHSS
Reese Dual Cam
Family of 4 saved by Grace!!!
MY TRUCK
OUR TRAILER
tvman44
Southwest Louisiana
Posted: 07/05/08 01:23pm Link  |  Quote  |  Print  |  Notify Moderator
You will probably find there is also a 30 and a 15 amp connector there. Never saw a 50 amp only.
Papa Bob
1* DW "Granny"
Husky 16K hitch, Tekonsha P3,
5erTrailerTrash
Anchorage, Alaska
Posted: 07/05/08 01:26pm Link  |  Quote  |  Print  |  Notify Moderator
Nevertheless, the answer is that with the proper adapter it will work just fine. I do it at home routinely.
mike54
Woodstock,IL
Posted: 07/05/08 01:51pm Link  |  Quote  |  Print  |  Notify Moderator
I never saw a post having 20 amp and 50 amp but no 30 amp intil this weekend we plugged into the 50 amp with an adaptor.
Mike
2008 ZT25RK CrossRoads Zinger
Wi. rallys attended IL. Rallys
2002 Silverado crew cab 2500HD 6.0 4:10 gears
VernM
Marion County, AR
Posted: 07/05/08 01:57pm Link  |  Quote  |  Print  |  Notify Moderator
Consider voltage similar to water pressure and amperage the size of the pipe. As long as your needs are met by the pressure (120 volts) and the size of the pipe you need is smaller than what is shown (at or lower than 50 amps), you're good to go -- with the right connector.
VernM
GMC Conversion van/Wells Cargo MiniWagon trailer
Sent via HughesNet/SatMex5 Internet Portal
fatmanobx
kill devil hills, n.c.
Posted: 07/05/08 03:20pm Link  |  Quote  |  Print  |  Notify Moderator
We stayed at a CG about 3 weeks ago and the only site they had left was 50 amp only. We were in our C and had to use the adapter. EBRV spend the 25 bucks and buy a dogbone adapter to have just in case you do run into a 50 Amp only.
2003 Four Winds Infinity 37'
Kirk
Livingston, Texas.
Posted: 07/05/08 06:00pm Link  |  Quote  |  Print  |  Notify Moderator
The big up-side of using such an adapter is that 50A connections seldom have any voltage problems, while they are very common for 30A sites. There are several reasons but the main ones are that 50A connections tend to be much newer and the wire size if much larger.
Good travelin! ........Kirk
sent via Starband, Manual Flyer dish
www.adventure.1tree.net
