RV.Net Open Roads Forum: Class A Motorhomes: Charging Batteries with Your Generator
 > Charging Batteries with Your Generator
Deputy Chief P.O.
Linden, California
Posted: 07/05/08 09:39pm Link  |  Quote  |  Print  |  Notify Moderator
How long do you typically charge your batteries daily when dry camping?
jwmII
out west
Posted: 07/05/08 09:44pm Link  |  Quote  |  Print  |  Notify Moderator
All day with the solar panels. When the batteries get enough the charge controller shuts the panel down. If the batteries need more charge the controller turns the panel (s) on.
jwmII
JUrban
Delaware
Posted: 07/05/08 09:45pm Link  |  Quote  |  Print  |  Notify Moderator
Really depends on how low they were, what I'm using, and how the solar panels are doing. No fixed answer, but at least till I get to float charge.
John
2008 Tiffin Allegro Bus 40' QSP
2006 Chevrolet Colorado Toad
BlueOx Aventa LX Tow Bar
SMI Air Force One toad brake
Copilot Live Laptop 10 GPS
tomlang
Los Angeles area
Posted: 07/06/08 12:54am Link  |  Quote  |  Print  |  Notify Moderator
There are a lot of variables to tack down before anyone can give a true answer.
In my 20 year old Winnebago with two batteries in parallel and an old-style converter/charger, it might take a full day (24 hours) of charging at a uselessly low charge rate to recharge the batteries.
In my new to me 5 year old Foretravel, the three humongous batteries in parallel can probably be recharged in a couple of hours by the very smart 3-stage charger built into the inverter.
I read somewhere that Monaco recommends two hours of generator time daily to keep the batteries charged when dry camping.
* This post was edited 07/06/08 03:27am by an administrator/moderator *
Tom and Lynne
Tom is an Electronics Engineer, Lynne a retired teacher.
old rig is a 1988 Winnebago Superchief, currently on tour with the Blue Turtle Seduction (band)
new rig is a 2003 Foretravel 38' U295
Diplomat Don
Moorpark, Ca
Posted: 07/06/08 01:23am Link  |  Quote  |  Print  |  Notify Moderator
Deputy Cheif P.O.....We go to Yosemite every year at Thanksgiving. The blower on the heater puts a huge drain on the batteries overnight. It runs most of the night. We also use the lights, water pump and TV during the day.
In the morning, I turn the heater up to 70 and start the generator. I let it run for 2 hours and can typically get the batteries bach up to just short of float charging.
Don & Mary
2005 Monaco Diplomat 36SKT
400 Cummins
2007 Dodge Dakota 4WD
alcolby
yuma az.
Posted: 07/06/08 10:15am Link  |  Quote  |  Print  |  Notify Moderator
Your analogy will work for understanding the controller, but, the panels are always on, if they see sun.
The controller interrupts the circuit when the batteries are charged.
The only way to turn the panels "off" is to remove any light hitting them.
Al C
smkettner
Posted: 07/06/08 10:49am Link  |  Quote  |  Print  |  Notify Moderator
About two hours a day under heavy use. If they are real low in the morning I may run it an hour or two then. If the furnace or other draw will be on at night I charge for two hours right up to quiet time in the evening. Voltage at 11.8 to 12.2 the generator can get started. If it gets down to 30 to 40 amps charging the generator is shut off.
Deputy Chief P.O.
Linden, California
Posted: 07/06/08 01:52pm Link  |  Quote  |  Print  |  Notify Moderator
Part of our problem is that in the past we have woken up (after using the propane heater @ night) with an extremely low battery that won't start the generator. We have to let the motorhome motor start to charge the batteries enough to start the generator. We do not have an effective gage to measure the current charge of our batteries. I know this is a dumb question, but I know you experts will come up with a better way of doing business than we are currently practicing. Suggestions welcomed.
smkettner
Posted: 07/06/08 02:31pm Link  |  Quote  |  Print  |  Notify Moderator
How much battery do you have and what is charging them?
Tom_Anderson
Danville, CA
Posted: 07/06/08 06:41pm Link  |  Quote  |  Print  |  Notify Moderator
Most motorhomes that I've seen have a switch that will momentarily connect the chassis and house batteries together so you can "jump start" yourself if need be. That would let you use your chassis battery to start your generator. If you don't have one, you could probably have one installed pretty reasonably.
