RV.Net Open Roads Forum: Toy Haulers: Wolf Pack 30WP/ 2500 HD enough???
Search only in Toy Haulers
 > Wolf Pack 30WP/ 2500 HD enough???
Hardtime01
Central Fla
Posted: 07/06/08 08:53am Link  |  Quote  |  Print  |  Notify Moderator
I am looking at a new Wolf pack 30WP toy hauler. It states that it weighs 8100 lbs empty. I have never had a trailer of any kind to pull and need any advice. I want a generator, and most of the options. I will be hauling a 03 Harley Road King. I have the Class V hitch already on my truck and a Prodigy electric brake control. Any help would be appreciated...Mark
MudChucker
Winnipeg Manitoba
Posted: 07/06/08 09:16am Link  |  Quote  |  Print  |  Notify Moderator
hrmm.. seems the link to the spec sheet on the manufacture site is missing... well...do you happen to know what the GVRW is on the unit ? (fully loaded max weight ?)
2006 Springdale 292BHLS
2007 GMC Sierra 2500HD SLT 6.0
DuneJunkie
Rohnert Park, CA.
Posted: 07/06/08 09:22am Link  |  Quote  |  Print  |  Notify Moderator
you will not have a problem towing the 30' Wolfepack with a Chevy 2500HD. I am towing a 38.5 Fleetwood Gearbox and its 11,200 lbs.
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
MudChucker
Winnipeg Manitoba
Posted: 07/06/08 09:23am Link  |  Quote  |  Print  |  Notify Moderator
OK.. found the manufacture site...
http://www.forestriverinc.com/nd/default22.asp?page=floorview&model=30WP&choice=cher&nav=rec&name=3&series=WolfTTrailers
11532 pound GVRW so assuming 15 % on the tongue (unusually high number) that would be about 1700 pounds...add to that some passengers, fuel and additional cargo in the box of your truck... your at 2000 to 2500 pounds ... 500 to 750 pounds over the rated limit of the truck, for me is peanuts.. I'd do it without giving it any thought...a thousand pounds over... may be pushing it a little...
should note these numbers represent the extremes, a fully loaded camper... fully loaded truck and very full beer cooler !
fsujeeper
md
Posted: 07/06/08 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
we have the same trailer. it has a lot of tongue weight, around 1600# empty. we tow with an f350 dually. does well, but squats the back end. we love the trailer, and have most of the available options. if you have any questions shoot me a line.
mark
greyhd
Claremont, Ca
Posted: 07/07/08 11:39am Link  |  Quote  |  Print  |  Notify Moderator
Is the 2500hd diesel, 8.1, or 6.0?
The 6.0 would be hurting a bit, but with the others you should be good.
Hardtime01
Central Fla
Posted: 07/08/08 05:02am Link  |  Quote  |  Print  |  Notify Moderator
Its a 6.0 Gasser, 4.10 rear end 4x4 extra cab. Enough Truck, I do have the class 5 hitch??
goingnorth
Petersburg, MI
Posted: 07/10/08 10:54am Link  |  Quote  |  Print  |  Notify Moderator
When you say class 5 is it a reece 2 1/2" reciever or does the factory hitch have a v on it? Some ford factory hitches had a V on them but that doen't mean class 5. I'm not familier with other brands. The reese titan tow beast is the only hitch I know of that can handle #1700 toungue weight.
The dealer will tell you anything to make the sale, I learned the hard way, dealer said my jayco had #800 toungue wt, empty I have #1200 with no bat. propane or water, loaded i'm between #1600~#1700. Ask them to weigh the toungue or buy your own, about $115 for a sureline scale.
08 F350 FX4 CC SB 6.4L
(sold)99.5 F250 sc lb 3.73ls 4x4 100k
28' Jayco talon zx toy hauler 10,000# w/o toy's, tongue wt 1600# Titan Tow Beast wd hitch Dual Cam
22' Renagade 3place snowmobile trailer 2000# w/o toy,s
granite
ohio
Posted: 07/10/08 01:07pm Link  |  Quote  |  Print  |  Notify Moderator
We have the 6.0, 4.10 gasser crew cab, HD, truck camper pkg, 2005, which pulls our new FR 295'er toyhauler. Fiver weighs 8100 unloaded, and 1200 hitch wt. Only change I would make would be to go with a 8.1 big block engine for more 'just in case' power. No squatting under load, and 4.10 gives good startup acceleration. It will do for now!
MudChucker
Winnipeg Manitoba
Posted: 07/11/08 04:31am Link  |  Quote  |  Print  |  Notify Moderator
finally got my new truck out for a drive with my 30 footer... I took it down to the scales and weighed in... 6010 pounds loaded.. towed well, I knew it was back there but was very light work for the 6.0L..another 2 to 3 thousand pounds may be "do-able" but your truck will be working reasonably hard...
