RV.Net Open Roads Forum: Class A Motorhomes: 1990 Bounder problems
 > 1990 Bounder problems
77Casual
Berlin Wi
Posted: 07/06/08 06:22pm Link  |  Quote  |  Print  |  Notify Moderator
Hi, Sister in-law has a 90 Bounder they got last year, one of its million's of problems is with it running and you pull the yellow parking brake it blows all the oil out the top of the reservoir for the power steering and the pump growls as it blows the oil all over. It will empty the tank in about 2 seconds. Anyone have a idea what is wrong? This motor home has been cobbled up so bad before they got it I probably have a month of work to make it decent again. It has hydraulic boosted brakes also.
Tom
We have a 84 27ft Midas Kingston, a E350 Ford with 460 and a C6.
tom_kat
way upstate new york/lake george area
Posted: 07/06/08 06:46pm Link  |  Quote  |  Print  |  Notify Moderator
it has hydraulic boosted brakes with a air parking brake sounds like something is hooked up wrong someplace .dont think i ever seen one set up like that.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
77Casual
Berlin Wi
Posted: 07/06/08 07:37pm Link  |  Quote  |  Print  |  Notify Moderator
Air works the parking brake? I didn't know that. Then it must be blowing the air into the hydraulic system. That would make sense the way it blows the oil all over.
itsalleasy
Posted: 07/06/08 07:55pm Link  |  Quote  |  Print  |  Notify Moderator
What chassis?
77Casual
Berlin Wi
Posted: 07/06/08 08:52pm Link  |  Quote  |  Print  |  Notify Moderator
I think its a Chevy P3 16,000 GVW. Does that sound right? I don't know the wheel base or length of it off hand.
tom_kat
Posted: 07/06/08 08:54pm Link  |  Quote  |  Print  |  Notify Moderator
i dont know for sure if it has a air parking brake you said the yellow button for the parking brake and thats what air brakes have for a parking brake valve.it may or may not be air.if its a p-30 it must be chevy is it a diesel or gas.gas doesnt have air.
77Casual
Berlin Wi
Posted: 07/06/08 09:55pm Link  |  Quote  |  Print  |  Notify Moderator
Its a 454 gas engine. I found a chassis manual in the big bag of books inside the motor home. From the little I was reading it looks like the 1990 brake system was a one year only thing, 91 to 93 is different. It looks like the trans don't have park in it, there is a valve on the shift linkage that applies the parking brake when the shift lever is in park. It also looks like some of them had the parking brake on the end of the trans, not at the rear wheels. It also says the parking brake is on all the time under spring pressure and the hydraulic system releases the brake? He said when it was way low on power steering fluid he couldn't move it because a brake was holding it, which goes along with what I was reading in the manual, so it must be working, but why it blows all the oil out of the tank with allot of pressure when the parking brake is pulled with the engine running I don't understand yet.
There are allot of things on this motor home I don't understand why they are built like they are. Worst part is the wiring is all messed up, and it has more wires in it than our house I think LOL. The owner got hold of the company that built it and they sent all the wire diagrams they had for the thing, so maybe I can figure out some of that mess.
Tom
Gale Hawkins
Murray, KY
Posted: 07/06/08 10:16pm Link  |  Quote  |  Print  |  Notify Moderator
It is being overfilled? It needs to be checked WITHOUT being in Park the best I remember. There may be a bleeding issue but it has been a while since reading about the Auto Park since I learned my 1992 chassis was only rated at 14,800 lb so I have the pawl and no Auto Park.
Send a PM to oldusedbear because from what he sent me he as the best Auto Park library around and he will share it with you.
tropical36
Southwest Florida_USA
Posted: 07/06/08 10:34pm Link  |  Quote  |  Print  |  Notify Moderator
Sounds like auto park...and a bad ....rotten green switch to me. Probably ruptured as they are noted for...accounting for the rapid fluid loss.
Like Gale says, you might as well contact our world famous expert on the matter, so as to get it resolved quickly.
"We are often so caught up in our destination that we forget to appreciate the journey."
"It wasn't raining when Noah built the ark."
1998 36ft. National Tropi-Cal, with a tag axle and one slide, on a 1997 P32 Chevy chassis
Gale Hawkins
Murray, KY
Posted: 07/06/08 10:57pm Link  |  Quote  |  Print  |  Notify Moderator
Message from oldusedbear today.
Tropical36 that hit my mind until I reread it was a 1990 and it was blowing it out the power steering. The rotten green switch issue came later (1994?) when Auto Park got its on pump.
Blowing out the oil may or may not be a huge issue.
