blasterx2g
casselberry , fla/seminole county usa
After months of slowly fixing the extensive water damage to my Wanderer wagon its all done. Took some advice I got on her also so I thank everyone that chimed in. The whole floor and the rear walls are better than new and is actually stronger. Im going to try to sell it now. The whole thing has just turned me off to camping for now along with the high gas prices. How much would a 2004 thor wanderer wagon be worth. It has most everythig but no generator.
Moderators Edit: Added Image Tags to the photos would show up inline.
edited 07/06/08 10:20pm by an administrator/moderator *
24fb freedom
littlerock,ca
Looks great!!! Nice work.
DuneJunkie
Rohnert Park, CA.
great job.........looks awesome!
2005 Chevy 2500HD 4x4 CC Duramax/Allison, with 18K SuperGlide Hitch
2008 385 Fleetwood Gearbox
2005 Yamaha YFZ 450
2002 Honda 400ex
BobWanderer
Perris,Calif,USA
Obviously the damage was in the cargo area.
Ours has bowed up in the center of the cargo area, when you walk on it it flexes downward.
Is this what happened??
I don't know what caused ours to bow, but now I gotta assume that its water damage?? I would think that after sitting for a few weeks in 100+ temps that it would dry out and return to somewhat level.
Did you have to replace the wood framing or just the plywood and linolium.
Thanks in advance.
Bob J
2008 GMC 2500HD 4X4 Dizzle CC LB
2004 Thor Wanderer Wagon 247WTB
2006 TE450 Husky
2007 Rhino Sport Edition
MEMBER AMA and CORVA
blasterx2g
When i would walk on it the floor would sink. My foot would have gone through exept for the linoleum on top keeping it from doing that. I knew i had to do something when both of the beds ripped out of the wall one night. Had to replace all the framing in rear walls. The floor rails held up fine but the cheap subfloor disenegrated.The water was coming in from the top of the rear windows. after i gave everything a good caulking its water tight. If you need pics or helpful hints email me at blasterx2g@yahoo.com
BobWanderer
Perris,Calif,USA
Thanks Blaster,
I think the walls are O K.
The floor is arched up in the center about 2" and some of the screws that hold the tie downs have pulled out of the cross members.
If I can get away with replacing the plywood floor and linolium I will be happy.
Thanks again for the info.
damone
Paradise,CA
The screws came loose on mine too. I just went through and added washers and nylock nuts to each screw. Some of the screws had missed the angle iron and were only fastened through the wood floor. Placed large washers on those to spread force and get some of the angle iron for backing.
D-rings are solid now.
"Honey, are the brakes suppose to touch the floor"
RideRed,
D
