wely
Columbia, SC
we currently have a 24' class C but momma says we should get a bunk house. We have 4 kids and its hard to find a vehicle big enough to tow behind the rv. Here is the question? Which companies have the best bunk house for the money. momma wants it to sleep 6 with out having to break down the table or couch. We have an excursion so I believe we can tow up to 10,000. V-10, 4.30 gears.
May the peace of Christ go with you always
2002 Toyota 4runner 2wd (DW)
2000 Excursion V-10 4x4
1998 Fleetwood Tioga 24D, V-10
1997 Ford F-150 V6, 4x4
Coachman Truck camper
1946 CJ-2a (DW's Grandfather's farm jeep)
crappie_fisherman
Fort Wayne, Indiana
Jayflight 32BHDS
I tow a Jayflight 31BHDS (so I'm partial to Jayco's) with a V10 4.30 geared Excursion...I've made some slight modifications to my Ex's suspension that REALLY have improved things.
I've towed 17,000+ miles and counting in the last 3 years with this Excursion thru all parts of the country...the Ex 'can' be an incredible TV...but also can be a handful...the Hensley don't hurt either!
The TT I linked to above will sleep 6 (including you and your wife) without folding tables down...
Good luck and let me know if I can help in any way.
Joe.
DH, DW, 2 DD's
2005 Excursion V10 w/4.30's
- Hensley Arrow
- Prodigy
- Hellwig rear sway bar
- RoadMaster Suspension
- Front 2" hitch
- Bilsteins
2007 JayFlight 31BHDS (3 women & 2 slides...it helps! )
Mini & the BEAST
Hornet28BHDS
Parker, PA
There are a lot of floorplans out there that will fit your needs. The Ex is all the TV you need for almost any TT on the market today, so just take your pick!
edited 07/08/08 08:08am by Hornet28BHDS *
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
Life is short, why not spend it in an RV!
SPRING HAS SPRUNG!
hotbyte
Barnesville GA
There a lots of nice quad bunks available now. We've really enjoyed our Pilgrim 5'er. Here's link to Pilgrim 1500 TT floorplans. The 28PQB abd 29PQBC are both quad bunks with 2 of them being wider than typical for older kids. When looking at bunks, be sure to check the width and length on the bunks.
Our Web Albums
For pulling...2005 Chevy 2500HD LT D/A and 1998 Dodge Durango SLT 5.2L
To be pulled...2002 Glastron GX205 and 2005 Pilgrim 276BH-5SS 5'er
ajmcd1970
Bakersfield
The Keystone product line has a few out there.
I had a Cougar with 2 beds in the back. We used it 14 times in 10 months. I have seen a Cougar withe same floorplan but with the quad bunks. It's nice and price is fair.
Good luck. Happy camping!!
2007 Chevy Silverado Duramax Diesel
2007 Cougar BHS2110 replaced by....
2008 Fuzion Z393
No toys yet!!!
1 Husband, 1 Wife, 1 Boy, 1 Girl, 1 Designer Dog (A mutt)
browns329
New Jersey
Most TT manufacturers have a model with quad bunks in the rear. TT's with 2 slides are also nice (like the Jayco 32BHDS link from crappie fisherman), but they usually run a few thousand dollars more than the quad bunk models. I think quad bunks are a little easier to find if you are looking for a used one (at least in NJ), since I assume the 2 slide models haven't been around as long. of course it also depends on how much money you can spend!
2003 GMC Yukon XL 2500 (3/4 ton), SLT, 4x4, 8.1L, Autoride, 4.10 gears
Putnam XDR, Equalizer 1400#, Tekonsha P3
2008 Jayco Eagle 314BHDS (Bunk house double slide)
Me, DW, 2 DD, lots of pets
RVcrazy
Puyallup, WA, USA
Take a look at some of the Spree (KZ) floorplans.
bigslim
NC
I have this one.
Dutchmen 29Q-GS
http://www.dutchmen-rv.com/floorplans.php
Quad bunks in back and queen up front. Very lightweight as well!
04' Ram 3500 2wd, 5.9 CTD, 6-speed
04' Prowler 295BHS 5'er
The wife and the kid!
EnglishBulldog
Maryland
Have the Keystone Outback 30 BHQ with quad bunks; thought about the Courgar 29 BHS but the weight was less with the Outback + the Outback had overall better numbers: Fresh water: 50 gals vs 45; Grey and Black tanks: 40 gals each vs 28 gals. LP capacity: same; weight = 5975 lbs vs 6085. TT is a Chevy Silverado crew cab.
Good luck in your research.
zackyboy3rs
Eastern North Carolina
Check out the Puma brand. They have a couple of diffent layouts with quad bunks. From what I hear they are pretty well built.
