RV.Net Open Roads Forum: Tech Issues: Flexible Gas Line Available?
 > Flexible Gas Line Available?
tom_kat
way upstate new york/lake george area
Posted: 07/08/08 07:35am Link  |  Quote  |  Print  |  Notify Moderator
they use soft copper bendable tubing for propane gas ,its natural gas you can not use copper tubing with.
1985 Class A Holiday Rambler Imperial 33 +1979 Class C Holiday Rambler Statesman 1000 = 24 ft
C-Leigh Racing
Nashville NC
Posted: 07/08/08 07:57am Link  |  Quote  |  Print  |  Notify Moderator
deanowe wrote:
something to do with copper sulfates and nat. gas it maybe only a new york code?
Never heard of that, but I guess in NY could be in the code because of all the chemicals filtering in all over the state from the love canal & water ways.
Wouldnt be surprized if just about anything you could think of to use is aginst the code in NY.
jhilley
Buxton, ND
Posted: 07/08/08 08:58am Link  |  Quote  |  Print  |  Notify Moderator
The BBQ hose should work well if it has the right connectors on it.
slides
Piedmont of NC
Posted: 07/08/08 05:49pm Link  |  Quote  |  Print  |  Notify Moderator
I work for a municapality that serves customers with natural gas and we do use copper tubing to hook up heating systems hot water heaters stoves and dryers.
03 Ford F-250 Super Duty Super Cab SB 4 x 4
6.0 Turbo Diesel 3.73 Gear
Torqshift Trans
'06 Rockwood 5er 8283SS
Use And Promote CB Channel 13
KEBrown
Kansas
Posted: 07/08/08 05:59pm Link  |  Quote  |  Print  |  Notify Moderator
Fridge installed. Used a bbq grill hose to span the gap; it fit, now we'll see if it really works.. I'll post the update. I put in a Norcold 641, hope it's a good'n.
deanowe
long island ny
Posted: 08/05/08 05:25am Link  |  Quote  |  Print  |  Notify Moderator
I dont think you want to compare building codes with n.y or CA ! and we dont get hurricans,go figure?
javaseuf
Southern Cal
Posted: 08/05/08 11:43am Link  |  Quote  |  Print  |  Notify Moderator
I have serviced and built RV's for many years and I now work at a HVAC supply store.
Copper can be used with propane or natural gas but the copper will eventually flake inside with natural gas and could cause an orifice to clog so with natural gas, you want to use black iron pipe and then use as short a run as possible to the appliance from the black pipe with the corrugated copper or stainless steel flex line. These flex lines are also available in stainless steel.
You DON'T want to use the flexable copper or stainless steel lines that are used on residential stoves or appliances in a RV!! I just went through this installing my Olympian Wave heater and I called my vendor that supplies us with these flexible copper lines and he confirmed my suspisions that they are NOT designed to hold-up under vibration and they are NOT to be used in a RV.
I suggest, as another has suggested, that you either extend the current line with soft copper or replace the line with the correct length.
Steve
2007 Springdale 291RKL
2003 F150 King Ranch
1991 Palomino Mustang PUP
Eureka Timberline Tent
Yamaha IF2400isc
Yamaha EF3000iSEBC
