Has anyone had problems with the 2007 Pegasus leaking. We just purchased are 18fb Pegasus in July 2007 and we are having problems with it leaking and wall paper bubbling by the bedroom window inside. We are having problems with the place we purchased it from to do the warranty work. Any suggestions would be great. We are new to the travel trailer world. We have only owned pop ups.
We do love the Pegasus and are thinking of getting a bigger one. But we are worried about problems with them.
If you can afford it, it sounds like a good time to let the old Pegasus go. Check the new one over really well and make sure there are no chances for leaking.
2006 Hornet 28BHDS-Bunk House, Dual Slides
2006 Dodge Ram 2500 HD
5.7L Hemi, Factory Towing Package
Reese Brake Controller, WD Hitch and Sway Bar
If the dealer won't step up to the plate, contact the manufacture ASAP. I would also send an e-mail (with photos) to the manufacture and copy the RV dealership. Make sure you inform the manufacture the "lack" of response you are getting from the RV dealership. When you are dealing with RV leaks, you want a paper trail established ASAP referencing dates, names, and who said what.
Turk2500
05 Jayco Eagle, 278FBS, UVW 7,063lbs, GVWR 9,000lbs.
Tongue Weight: Dry 913lbs/Loaded 1,200lbs.
02 Chevy, 2500HD/4x4, 6.0L/4:10, EC/LS/SB, Prodigy, GCWR 16,000lbs.
TV/TT loaded: 14,700lbs.
Putnam XDR Class V, Reese HP Dual Cam.
00 HD Road King Classic.
TURK2500 wrote: If the dealer won't step up to the plate, contact the manufacture ASAP. I would also send an e-mail (with photos) to the manufacture and copy the RV dealership. Make sure you inform the manufacture the "lack" of response you are getting from the RV dealership. When you are dealing with RV leaks, you want a paper trail established ASAP referencing dates, names, and who said what.
My 2007 Pegasus had a leak through the front window. The dealer tried sealing the window, and ultimately had to replace it with a new one. Problem is solved, no more leaks.
