RV.Net Open Roads Forum: Tech Issues: ScanGauge with Insomnia
 > ScanGauge with Insomnia
oldusedbear
Brookings, OR, USA
Posted: 07/08/08 01:33pm Link  |  Quote  |  Print  |  Notify Moderator
My dandy new ScanGauge wakes up every 5 minutes or so - - Stays that way for maybe 15 seconds, and then snoozes off again.
Do they all do that or is mine just a poor sleeper?
Haven't driven the rig since installation.
The reason for spelling is so that all of the words don't look the same.
aslakson
Fulltiming in the Lower 48
Posted: 07/08/08 03:00pm Link  |  Quote  |  Print  |  Notify Moderator
Mine sometimes does that - takes a reset to get it going again. Ignition off and back on again usually does it - so does unplugging the data cable and then plugging it back in. My ScanGauge is happiest when the engine is running - because that way there's a computer for it to actually monitor.
al
ronfisherman
SE Michigan
Posted: 07/08/08 04:59pm Link  |  Quote  |  Print  |  Notify Moderator
Mine does the same thing when the trickle charger is hooked up. Shut it off and Scangauge stays off. But I do not know why.
Saf-TTE tire monitor
oldusedbear
Brookings, OR, USA
Posted: 07/08/08 06:52pm Link  |  Quote  |  Print  |  Notify Moderator
That's interesting about the trickle charger. I DO have one running on the chassis battery. Many thanks - - will check it out and report back.
frankandvicki
Niwot,CO
Posted: 07/09/08 07:42am Link  |  Quote  |  Print  |  Notify Moderator
I believe they are designed to timeout if the engine is not running to save on battery. Mine will come on as soon as I hook it up, push any button or supply power to it (plug it in) without the engine running. Mine stays on all the time once the engine is running. I do not have my manual at home to check to see if it is stated as to what to expect.
Frank O.
Frank and Vicki
Niwot, CO
2006 Itasca Sunrise 35A
States visited/camped in, not just driven through.
Oldfordman
Marysville, WA
Posted: 07/09/08 03:58pm Link  |  Quote  |  Print  |  Notify Moderator
Even if it does come on it draws about as much power as the memory circuit in your radio. It is not going to drain a battery unless you don't drive the rig for a year.
Life is full of choices. I choose to have fun!
Clay L
Sioux Falls, South Dakota
Posted: 07/09/08 04:20pm Link  |  Quote  |  Print  |  Notify Moderator
I talked to Scangauge about that quite some time back.
The way it comes out of sleep mode is when a senses small increase (a couple of hundred mili-volts as I recall) in the dc voltage it sees on the OBD connector. I have a BatteryMinder connected to the engine battery that causes mine to wake up when it bumps the float voltage up from time to time.
Any device that causes a change in the voltage will cause it to wake up.
Clay (WA5NMR), Lee,(Wife) Codi, Brandi (Shelties) and Damncat (damn cat)
Full Timing in a 2004 Winnebago Sightseer 35N, Workhorse chassis, Honda Accord toad
mooreadventures
North Carolina
Posted: 07/09/08 05:23pm Link  |  Quote  |  Print  |  Notify Moderator
Do you have anything plugged in to the cigar lighter? That is where most OBDs get there power from, so if you have something plugged in that is pulling voltage it could be making the ScanGauge think the OBD is trying to talk with it.
This does not happen with mine. I have it loose connectivity while driving for some reason, but only once so I think it may have been loosely plugged in.
Mark & Tammy
'01 Excursion Limited, 4x4, V10, RoadMaster Active Suspension
'01 Prowler 31G
Equal-i-zer Hitch - Prodigy Brake Controller
Rick Jay
Greater Springfield area, MA
Posted: 07/09/08 06:59pm Link  |  Quote  |  Print  |  Notify Moderator
My experience with it is exactly as Clay L states. If something "bumps" the battery voltage it'll wake up, look around, and then go back to sleep.
~Rick
2005 Georgie Boy 3625 DS on a Workhorse W-22 (Class A)
Rick, Gail, 1 girl (12-Angel), 1 girl (7), 2 boys (8 & 5), 1 plump Golden Retriever.
2001 Honda Odyssey with Demco Aluminator tow bar & tow plate, SMI Silent Partner brake controller.
oldusedbear
Brookings, OR, USA
Posted: 07/10/08 07:29pm Link  |  Quote  |  Print  |  Notify Moderator
I unplugged my dribble charger. The ScanGauge has been snoring ever since!
Thanks for the good input from everybody.
