RV.Net Open Roads Forum: Tech Issues: onan diesel generator overheat
 > onan diesel generator overheat
tjg72139
Phoenix, AZ
Posted: 07/08/08 02:26pm Link  |  Quote  |  Print  |  Notify Moderator
3 cyl. Onan diesel generator in Class A motorhome. Has 770 hours.
New oil, oil filter, air filter, fuel filter. Cooling system flushed and refilled per specs. Coolant system bleed of all air and water pump belt replaced because it broke. Coolant circulation appears normal but have no way to measure flow.
Shuts down due to overheating in about 5 minutes with heavy load.
Note; we use this diesel pusher at "the dunes" in AZ and CA and need the AC's to work. This is the 1st time we've had any problem.
We are considering add on electric radiator fan.
Note; ambient temps. are running 110deg.F to 120deg.F.
What experience or advice is out there?
Thanks.
pulsar
Lewisville, NC
Posted: 07/08/08 02:46pm Link  |  Quote  |  Print  |  Notify Moderator
Moved from Forum Technical Support to Tech Issues.
2002 Adventurer 32V - Workhorse chassis
1998 CRV toad - manual transmission
Have you seen the RV.Net Blogs? You can subscribe at Blog.RV.Net
Big Katuna
Deland, FL
Posted: 07/08/08 02:51pm Link  |  Quote  |  Print  |  Notify Moderator
I have that same genset so am interested in the thread. We have about a thousand hours on ours and have only changed fuel filter once, oil and filter every 150 hours. Coolant still in spec the last time I looked.
Did it used to work ok in this heat before the new belt?
And do you get a code?
My Kharma ran over my Dogma.
dons2346
Sioux Falls, SD, formerly of So. CA
Posted: 07/08/08 03:25pm Link  |  Quote  |  Print  |  Notify Moderator
Check the oil level and make sure you didn't over fill it.
Overfilling can cause the oil to foam up which causes lack of cooling and proper lube.
STINGRAYRVMAN
PANAMA CITY
Posted: 07/08/08 03:44pm Link  |  Quote  |  Print  |  Notify Moderator
I place my bet with dons2346. too much oil or sometime the brand of oil is usually the cause of a quick shutdown like this. I have never seen an Onan diesel overheat, I think if it did it would be quite a bit longer than 5 minutes on a diesel.
axle234
Pasadena,Md.
Posted: 07/08/08 05:08pm Link  |  Quote  |  Print  |  Notify Moderator
I had a similar problem and it was a board, I could actually put ice on it to get it runing again. Gunny was a big help on line here solving the problem. Do a advanced search to get similar issues.
Happy Rving!
axle234
2008 Fleetwood Fiesta
Toad- 99Honda CRV
gunny357
North Carolina
Posted: 07/08/08 06:48pm Link  |  Quote  |  Print  |  Notify Moderator
Model/spec/serial number will help, then we'll see what you see.
How do you know it overheats? Boils over? Shuts down and displays a fault code?
Belt broke. Tell us more about that.
Any exhaust smoke when running?
tjg72139
Phoenix, AZ
Posted: 07/10/08 05:28pm Link  |  Quote  |  Print  |  Notify Moderator
Worked fine for 2 summers. No problems. Yes, it shuts itself down and sets a code 33. Will recheck the oil. Really don't know why the belt broke. Didn't catch it until it fell out the bottom. Water pump turns freely by hand.
Possible T-stat problem?
What do you think of add-on electric radiator cooling fan?
gunny357
North Carolina
Posted: 07/10/08 05:44pm Link  |  Quote  |  Print  |  Notify Moderator
Possible air lock in the cooling system.
How bad did it overheat the first time? Any chnace it warped the head and blew the head gasket? That was the reasoning for the question concerning the exhaust smoke.
Sholdn't need an additional fan. for cooling. Mine did fine in 115 degree heat running basement air with both compressors running.
Don't have the manual close to hand. What is the verbage for a code 33?
