RV.Net Open Roads Forum: Norcold 662 , only works on propane !
 > Norcold 662 , only works on propane !
WaldoWild
Attica , Michigan
Posted: 07/08/08 06:56pm Link  |  Quote  |  Print  |  Notify Moderator
My fridge will only work on propane , if you put switch in automatic it just works on propane and that is with the motorhome plugged in to shore power . In March we went to Florida and it would only work on electric , so I vaccuumed the burner for any residue and now this , this is some funny stuff ! Could it possibly be the humidity/normal/storage switch ? Any help would be appreciated . The coach is a 93 Winnie Brave 31 with 454 and it has 57,000 and not abused , Thanks Waldo
lat471
Lebanon, PA
Posted: 07/09/08 05:50am Link  |  Quote  |  Print  |  Notify Moderator
When you switch it to electric do you get a code?
07 Cameo LXI F35FD3
R Taj-We-Haul
WaldoWild
Attica , Michigan
Posted: 07/09/08 06:30am Link  |  Quote  |  Print  |  Notify Moderator
When I switch it to automatic it just goes back to gas , I don't know where I would get a code ? I'm looking at fuses today with my fingers crossed , Thanks
JFG
TN
Posted: 07/09/08 07:22am Link  |  Quote  |  Print  |  Notify Moderator
Assuming circuit breaker is not tripped, check to see what voltage you have at the outlet that the refer is plugged in to. Must be over 108 or refer will not recognize it. If voltage is ok, there is a glass type automotice fuse on the circuit board (5 1/2 amps). See if it is blown. If blown, replace. If ok, you need a new board.
Fred
