I have a bigfoot auto level system, when you press auto, the air empties and the system starts to level. The last time I had to retract the feet manually to start the unit. I have no lights now to the unit and can't level the coach. Any idea's
Big Foot is not air but hydraulic. If "auto" doesn't work and "manual" does you have a bad control box (inside). Each "foot" is independently controlled by it's own motor and hydraulic pump. If you start your generator/engine, will the big foot work fine? If so, you have a bad battery; that was my problem; or you simply have a loose connection or blown fuse if you have ZERO power at all.
I,m assuming it didn't do the air dump either? Does it even show the all up light lit? If the answers are no it would seem like it is power issue to the controller. Even with low batteries the controller should light up.
When you say you had to manually retract the feet do you mean bleeding the hydraulics at each pump?
